alko rear suspension (1 Viewer)
stewrty
14
help i cant get my rear wheel off the rear suspension seems to be seized any tips on trying to free it thanks
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
there are a number of posts on this I believe. The Alco rear axle/suspension needs greasing approx every 6 months. I hope you are able to free it as replacement is expensive. Dave Newell is the man to ask, he is a trade member here. Good luck
S
stewrty
14
rear suspension
no the rear suspension arm wont let the wheel come down low enogh to come off so must be seized cheers
lunarman
2,157
2,453
South Glos
since 1994
What van have you got?
It is very difficult to get the rear wheels off of my van (lunar Roadstar 786) because the fairings the converter added to the body fowl the wheel when trying to remove it.
Are you sure its not just a design feature of the conversion.
Lunarman
chrisgreen
Jul 26, 2009
5,980
12,332
england
c class
since 2004
if you need to grease it jack both wheel's off the ground and you will find 2 grease nipple's on the axle one each side,pump as much grease as it needs untill you cannot get any more in,do every six month's:thumb:
chrisgreen
Jul 26, 2009
5,980
12,332
england
c class
since 2004
another point.
never try and strip the suspension down if you aint sure what you are doing as it is a pre-loaded torsion bar setup.:thumb:
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
If it is siezed (and I have seen them sieze up) then you may be lucky and it can be freed off, takes time, serious heat and lots of wd40 and grease. If it won't free off then the axle is scrap and will need replacing as a complete assembly.
D.
D.
Disgraceful.
The designer should be shot.
I've got a distant memory of something similar with VWs long ago, tales of cutting open a tube to do a repair.
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
It may be something as simple as jacking the body off of the axle to get the clearance. you don't say where you are but many trade members here. to find a particular member look in the members list (under community+)
S
stewrty
14
suspension seized
yes it is defenetly seized sold in the up position there must me a trick in freeing it big hammer and wd 40 cant get greese in as torsion bars seem to be covering the holes as have taken nipples of to get wd 40 in van is 21 years old has it ever been greesed in aberdeen by the way cheers:cry:
aba
2,775
1,112
yorkshire
dec 2009
you may be able to get a scissor jack in between the trailing arm and the chassis but if its been seized a while you may just have to bite the bullet and get a new one.
i wouldn't trust a second hand one as you just don't know what its done or how its been serviced ( if at all ).
S
stewrty
14
seized suspension
thanks i would try the jack idea but very flimzy body work around there cant aford a new one i will try any thing its an old swft kon tiki but a good van for its age cheers
aba
2,775
1,112
yorkshire
dec 2009
if you can remove the shock absorber you may be able to jack it down on the shock absorber mounting points but be very careful just how much pressure you put on them if you can get it to move a little bit even a couple of mm then you are going to have to then transfer the weight of the van back onto the wheel to move it back the other way.
if you have to apply heat to the axle tube shield the van floor with aluminium above where you are warming and have a fire extinguisher handy as motorhomes burn very quickly.
S
stewrty
14
seized suspension
thanks for that idea i will give it a try a let you know thanks again:thumb:
S
stewrty
14
seized suspension
well i have taken off the shock hoping to atempt to jack the torsion bar arm down but the top of the shock is just a bolt hole any ideas cheers:cry:
