AAaaarghh, possible gearbox failure (1 Viewer)
andy63
4,672
15,018
south shields
since 1990
eventually discovered that it was the egr valve clogged up, very clogged actually, got that cleaned out, problem solved, phew..
(by the way, i know bugger all about modern engines, do all of them have egr valves?)
hi dryad Andy @Techno100 had a thread running on the problems they could cause ...ie similar experience to yours...
I did some work on my transit to clean up the intake side and then got it re mapped to delete the egr function out of the ecu. cheaper than replacing egr valves..
Link to thread if it works , its a long one :)
http://www.motorhomefun.co.uk/forum/threads/egr-valve-blanking-cheating.100210/
ta andy
Dec 12, 2010
5,415
21,601
Cumbria
(by the way, i know bugger all about modern engines, do all of them have egr valves?)[/QUOTE]
Afraid so, lots of posts on here and elsewhere about blanking them off, mind an occasional "Italian tune up" can be effective (y)
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
Italian TUNE UP is the way the EGR system is meant to be cleaned out a good trash is a very good way of clearing the cobwebs out of an engine, unfortunately it tends to be illegal with the performance of modern vehicles being so high.
11,956
16,570
As an aside 'limp mode' is normally engaged when a fault occurs that will compromise emission control. It is rarely (never to the best of my knowledge) engaged to protect anything mechanical.
Jul 18, 2009
11,200
17,855
HYMER B644
I run a couple of Sprinters with the 5g-Tronic Gearbox and a Mercedes S-Class.
They can be a bit tetchy and don't like duff chassis batteries.
Also best to get the Engine and Gearboxes warmed up a bit before you go thrashing them uphill-down dale. Especially if towing!.
TM
DavidG58
Feb 24, 2013
13,090
101,509
Bolsover, Derbyshire
Hymer S800
not long enough
TM
Could be an interesting point ref the battery, I do have a reputation for needing a jump start, so the new battery fitted yesterday can only help (y)
We have also found we need to leave our MH on tick over for a few minutes before moving off, or it really does not seem to want to pull away, may all be related to same issue, can only hope
Just about to call garage to see if we might still be away today
Aug 18, 2014
23,806
133,913
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
That's normally a Maf fault.Or the MAF to ecu readings not correct.
DavidG58
Feb 24, 2013
13,090
101,509
Hymer S800
not long enough
Right, time to close this thread, but unfortunately I am off to start another
The cheapish component is fitted not as hard to get to as they feared, but has now confirmed that things are more serious
Off to new thread
Mercedes Hymer Turbo woes
See you there maybe :(
