EGR valve blanking/cheating
Discussion in 'Tech/Mech General' started by Techno, Jan 10, 2015.
  1. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,188
    15,162
    Leeds the one up North
    Open discussion on the pro's con's of this from your personal experience or that of second party knowledge
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,116
    17,785
    YO11 2BD
    Probably need the ECU/PCM etc rewriting to delete the ensuing fault codes permanantly.
    the sensor may be able to be overridden using the correct resister but not sure.
    Why blank/bypass it ?
    • Like it Like it x 2
  3. Techno
    Jul 28, 2010
    14,188
    15,162
    The general feedback (interweb) suggests that where engines are driven lightly for economy or just general leisure like we do that the inlet manifold gets gummed up from recirculated gases.
    As I understand it with my 3 litre Iveco the solution is as simple as blocking the vacuum pipe that operates the valve with no other issues.
    Result...... cleaner burning better fuel economy.
    EDIT no fault codes as the ECU believes it has done it's job
    • Like it Like it x 1
  4. C200JK
    C200JK Read Only Funster
    Dec 27, 2014
    963
    3,174
    Ireland / London
    The people who designed it were no idiots, reason for it being there !
    • Like it Like it x 4
  5. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,286
    7,986
    West Norfolk
    Techno......
    Step....away.....from......the........toolbox!!!!!!
    If it ain't broke don't try and fix it!!!!!!
    Just my humble opinion!!!:)
    • Like it Like it x 5
  6. daveandsan
    daveandsan Funster
    Dec 10, 2013
    1,396
    1,982
    South Staffs
    I believe that if you blank or bypass the EGR valve it will fail the MOT, just try giving it a thrash up the motorway.
  7. pappajohn
    Aug 26, 2007
    30,116
    17,785
    YO11 2BD
    Emissions....... at the expense of power and economy and no other reason.
    • Like it Like it x 6
  8. Techno
    Jul 28, 2010
    14,188
    15,162
    Not detectable
  9. pappajohn
    Aug 26, 2007
    30,116
    17,785
    YO11 2BD
    Sorry, it will pass as long as it meet emissions requirements.....which it will if done right.
  10. jezport
    jezport Funster
    Oct 29, 2008
    1,895
    1,276
    West Yorkshire
    Done a few vehicles, the transit diesel engines have 3 different types of EGR one can be fully blocked, one needs a small hole leaving and the third cant be blanked at all as it throws ecu codes if blocked. Im sure earlier fiat EGR valves on the 2.8jtd can be blanked but they seem to be quite reliable without so not worth blanking. You have more issued on the more complicated EGR systems on the later DPF engines as they have more sensors and sometimes cant be messed with.
    Generally the EGR valves on motorhomes should be more reliable as trips are usually long and at higher speed. on diesel cars that do short trips the EGR and manifold will gunge up a lot more.
  11. Techno
    Jul 28, 2010
    14,188
    15,162
    In fact it is more likely to pass emissions with it blanked as it will only exhaust burnt fuel not recycled already burnt shite
    • Like it Like it x 3
  12. dave newell lvs
    dave newell lvs Trader-Vehicle Services
    Oct 31, 2008
    2,612
    3,429
    Telford, Shropshire
    Blanking off the EGR will NOT cause an MOT failure! EGR works at higher engine speeds and light throttle i.e cruising and this simply cannot be replicated without putting the power unit under load. It can, under some circumstances give better fuel consumption and a more responsive engine. My race car (Mazda MX5) had EGR fitted but I've removed it along with the CAT and fitted individual throttle bodies and yet it can still pass the MOT emissions test.
    D.
    • Thanks Thanks x 1
  13. C200JK
    Dec 27, 2014
    963
    3,174
    Ireland / London
    While that is true, simply blanking them can have consequences.
    Been in the game 30+ years and see problems all the time, an w211 e320 yesterday that someone "blanked"....
    While it can be done in some cases it may be necessary to re-map to solve.
    Same as these dreaded DPF's.... We remove tons of them and re-map the ECU to "disregard" them, still pass the emissions and all is good.... But removing them without doing so is asking for bother.
    But as the OP said, vacuum actuators on the valve could be blocked, but if flow rates are sensed incorrectly they can cause the car to go into "limp mode" ..... Bloody cars have got serious since I was a lad !
  14. pappajohn
    Aug 26, 2007
    30,116
    17,785
    YO11 2BD
    Sorry Andy...was thinking DPF at the time......that does need ECU delete, or it does on Chrysler diesels.
  15. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,286
    7,986
    West Norfolk
    Oh no!
    You've done it now Dave!
    Andy (Techno) will be on the phone to Dave for a prototype diesel Emerald ECU and a rolling road session!!!!:)
  16. andy63
    andy63 Funster
    Jan 19, 2014
    2,232
    8,579
    south shields
    hi andy (techno) ive read a good deal on the transit forum on the subject.. the mk6 lads just blanked them off but the mk 7 has a sensor in the manifold that responds to the operating egr valve and it cant just be blanked without causing problems. as papajohn said it requires a re write of the map to delete that function before blanking but I think you still need to leave it in place for mot purposes, as its original fit.
    why do it, well some vans get well carboned up in the inlet side and go through egr valves frequently, but others have done thousands of miles with no prob.. I think its got something to do with the way they are driven and type of use , but that's just my take..
    I intend taking the inlet side off my van this summer to see how bad the build up is , but I have cleaned the pressure sensor in the manifold about 3 times in 4 year and each time it was well caked up.
    if its really bad I may get it deleted and blank off.
    I cleared some fault codes the other day and one of them related to possible sticking egr, so hoping I can get a look before it becomes a problem
  17. Techno
    Jul 28, 2010
    14,188
    15,162
  18. Baggers53
    Baggers53 Funster
    Dec 30, 2013
    184
    221
    Stafford
    The EGR on my Renault Megane 1.9 cdi had to be replaced yesterday, due to carbon build up it had "clogged up" and striped two teeth on a cog and due this it was "hunting" and making very strange noises, especially when I turned the engine off!!! Total bill £360.00 .....the garage also looks after my motorhome and says it is unlikely to happen to this as the MH is used for long journeys and heat in the engine stops a dangerous build of carbon...is this correct??
  19. andy63
    andy63 Funster
    Jan 19, 2014
    2,232
    8,579
    south shields
    on switch off I think the egr valve goes through a self clean cycle. the transit does, so that may account for the noise, its trying too and cant cause its knackered
  20. Scattycat
    Scattycat Funster
    Jan 3, 2013
    844
    1,184
    Mayenne, France
    I have to disagree.
    Motorhomers in general will potter along keeping revs down to save fuel, so even on the motorway they will usually be keeping to or be below the speed limit with the engine ticking along at around 2000 revs.
    This provides the ideal environment over a long period for the engine to coke up.
    The engine management light comes on and the owner reads the manual which tells them to immediately seek out an authorised dealer who will inevitably suggest that the egr unit is defunct and insist a new one be fitted. Whereas, unless there is, which is unusual, a physical breakage in the unit, all that needs to be done is give the unit a good clean.
    The best way to avoid the engine being bunged up with coke is to give it a good thrash for a few miles at high revs to burn it off.
    I also once a year depending on mileage give mine a dose of a product called Forte added to a tank of fuel to clean away any build up of coke.
    Also part of my tool kit is an OBD2 code reader which will turn off the code that puts the engine into limp mode when the valve gets coked up.
