X290 fuel filter change (1 Viewer)
Sep 24, 2013
1,314
748
Norwich
Carthago A class
Since 2014
I know this is a straightforward change but how do the pipe fittings on the top come off. Pull? Twist? Do I need a special tool? I can't find a Youtube video of swapping it.
Misterg
221
213
N Wales
Self build PVC
Are they the connectors with a square looking coloured section like these?
If so, the coloured section slides sideways a few mm. You then need to find and press the almost invisible button somewhere on side of the connector. Once the button is pressed, the connections just pull off really easily.
Push them back on to refit and slide the coloured bit across.
May 31, 2015
11,689
44,556
Ducato PVC
Getting Better
Isn’t this picture of the fuel tank sender on the fuel tank and not the fuel filter in the engine bay..?
May 31, 2015
11,689
44,556
Ducato PVC
Getting Better
Sorry, missed the sentence above your picture, pic was for comparison...????
stevec
Sep 24, 2013
1,314
748
Norwich
Carthago A class
Since 2014
Nope, not like that. Seems to be a circular collar.
Aug 5, 2018
1,567
3,513
a
Squeeze the two oblong sections on the wide part of the collar. Can be a complete twat sometimes without the right pincers. When you get it right it just slides off like a greased stick but 90% of the time you spend 20 minutes trying to get the collars squeezed correctly ?
skylinersi
1,186
952
midlands
Van conversion
newbie
i believe, ist easy to crack something if youre not careful, i have seen threads about this, may be worth searching, and im sure on ebay i have seen a tool for doing the job. I would check first before attempting?
stevec
Sep 24, 2013
1,314
748
Norwich
Carthago A class
Since 2014
The filter is a metal canister with push on connectors (push on or twist..not sure). This replaced the plastic container with threaded top which did leak if not done properly.
