Isn’t this picture of the fuel tank sender on the fuel tank and not the fuel filter in the engine bay..?Are they the connectors with a square looking coloured section like these?
If so, the coloured section slides sideways a few mm. You then need to find and press the almost invisible button somewhere on side of the connector. Once the button is pressed, the connections just pull off really easily.
Push them back on to refit and slide the coloured bit across.
I know this is a straightforward change but how do the pipe fittings on the top come off. Pull? Twist? Do I need a special tool? I can't find a Youtube video of swapping it.
