Wiring of After market head unit.Help required please. (2 Viewers)
Dec 18, 2011
754
511
Hull
Autotrail 634
I have recently fitted an Atoto S8 head unit which I am really happy with.The only issue I have is that when i want to play around with it I have to turn the ignition on to run it.It is wired with a constant 12 volt supply(yellow cable)and a ignition switched (red).My question is if i put a small switch to override the ignition,ie connect the red and yellow,will it cause problems elsewhere?If anyone can suggest a better way to achieve my objective,I would really appreciate it.At the moment when i turn the ignition switch on,it turns on all my dash lights,along with the daytime running lights.It also isolates my hab battery which in turn turns off cameras and mifi unit.Thanks to anyone who can assist.
Jan 23, 2016
1,913
308,610
Wales
Adria Coral 660SP
25 years
Fiat Ducato?
There is a small switch/button/lever on the Steering Lock.
Holding that in as you turn the key one notch puts you in a accessory setting.
Radio on, Ignition off.
20160826_125835-jpg.170910
Mine is a bit like this, but not red and maybe not as large.
2,828
7,007
Ottershaw
Hymer S820
First motorhome May 2021
Red and yellow are connected on my Sprinter based Hymer, you must ofcourse remember to turn it off properly, on my Sony head unit it can be in standby displaying the time or a long press completely turns it off.
Tombola
4,902
15,912
Merseyside
Rapido 8094DF
Or also add a switched wire going back the leisure battery to use that power first unless you switch it off
