- Nov 6, 2008
- 4,041
- 41,531
- Devon Aztec XL
- 14 years with an RV
Can anyone recommend a good wireless rear view camera system please?
Craig
Craig
‘Always-on’, as a rear-view mirror, or just for reversing - or both?Can anyone recommend a good wireless rear view camera system please?
Craig
Both if possible.‘Always-on’, as a rear-view mirror, or just for reversing - or both?![]()
I have a Garmin 760 camper sat nav.Ok. The Garmin BC40 I use is for reversing (it’s attached to the rear number plate at low-level), and it only works with certain Garmin Sat Navs, so, if you haven’t got one of those, it’s a non-starter unless you buy another Sat Nav too…….
I have no experience with the Boscams as mentioned by phillipsheila - perhaps other Funsters can help….?![]()
hi what make is yours pleaseWhat I have always thought was a good idea was for a small camera that can link wirelessly to a phone. Not for reversing, but for using as a waste dump camera.
Reversing, I think that you are better off with a wired cam, with dual views. Mine points down to the towbar and back to the wider view. And it is always on.
Not sure, it came fitted as standard. I've just looked at the monitor that clips on the rear view mirror and there are no markings of any type on it.hi what make is yours please
Unfortunately the Camper 760 is not compatible with the BC 40, only the wired BC 30, I believe….I have a Garmin 760 camper sat nav.
Craig
I also have one like this which displays on a 8 inch tablet which is mounted on my dash. I only use it when needed and have had no interference issues.I bought one that doesn't need to be wired in because it uses a built in rechargeable battery. It attaches by strong magnets. I used it for a while waiting for my installed rearview camera to be replaced. No problems with interference. It uses an old mobile phone for display. However a disadvantage is that you have to turn on your phone, open an app and make a connection whenever you go for a trip and your partner gets ratty.
Rear view alway on camera
I fitted a WiFi camera to position us over the grey waste dumps to save the missus from getting to wet when it's raining.
In our bus, it is definitely a blue job!
Definitely interested in a wifi camera to do exactly what you have done. What make of camera is that? Is it 12v or battery? And doesn't it get covered in mud and stuff from the road?
