Which LPG connection for gas tank? (2 Viewers)
XRN
Oct 10, 2014
312
294
Plymouth
Hymer B680 Starline
We are no longer Newbie's.
I have an underslung gas tank (Hymer 680 2001 yr) and need to fill up this week before the Newbury meet next weekend. I have never done this before so I am not aware of what the garage pump connection looks like. I have 2 adaptors which came with the van which screw onto the gas tank fill point but I am not sure which one is correct for UK and where in the world the other is used.
Which ever one it is, what is the procedure at the pump, is it push on and turn to lock or what? Can anyone advise please?
Reactions: f6c
2,344
10,178
One on the left is for UK .. the bayonet connector
The other is the Cup connector for France , Italy and Scandinavia
How to fill..
http://www.go-lpg.co.uk/how.html
when connected, hold the fill button IN .. it can take a few seconds before filling starts ..
once started just keep holding the button.. it will stop filling automatically
XRN
XRN
Oct 10, 2014
312
294
Plymouth
Hymer B680 Starline
Thanks Jim, just what I needed. Now just got to find a garage that does LPG near me!
2,344
10,178
The very first time I filled up my Gaslow bottles I thought there was something wrong.. I connected the gun, then held the button.. but nothing happened.. tried several times and still nothing.. then it dawned on me.. :RollEyes:
I wasn't holding the fill button long enough for the system to pressurise and check the the integrity of the fill line.. it won't stat filling until it has done that..
mine being new the fill line was empty and it took longer than I expected..
glenn2926
3,326
13,619
Gods country
Chausson
newbie hired 3
First ensure the pump nozzle is turned fully anti-clockwise ,line up the bayonet connector lugs and push the nozzle onto the fill point. Now turn the pump nozzle clockwise. Then squeeze the handle to lock in place. Push and hold the button on the pump until it stops filling. Job done. It sounds more complicated than it is.
XRN
XRN
Oct 10, 2014
312
294
Plymouth
Hymer B680 Starline
Good point Jim I will bear that in mind when filling. Thanks to Glenn also, all becoming clear now.
Jan 10, 2013
5,958
7,354
Near Uttoxeter and Crete
Warwick XL PVC
Still trucking and learning
Suggest you wear gloves 'cos the gas is VERY cold and can burn if you get it on your hands. Also, when you disconnect you will probably hear a big hisssssss - can be a bit frightening at first but it is normal.
XRN
XRN
Oct 10, 2014
312
294
Plymouth
Hymer B680 Starline
I use FillLPG, mainly its Android app on my phone. Once you've filled up the first time just top up as you pass a convenient fuel station on your travels, that's what we do whenever possible.
I found the FillLPG site just after I posted, looks pretty useful and appears right up to date
GJH
29,450
38,827
None, now sold
2006 to 2022
Good point. I use a pair like Broken Link Removed. Also good for gripping the adapter to unscrew it if it is a bit tight.
You can use the app to update it so I do so when we buy gas and, sometimes, when we pass a fuel station if I'm the passenger. The more people do that the more accurate it is.
Apr 27, 2016
6,874
7,998
Manchester
A class Hymer
Since the 80s
Probably not top of your priority list right now, but if you go to Spain you'll need a different one. Best to get it before you go, from wherever you got the other two.
scotty1
254
38
Kent
Wildax solaris xl
What does Spanish one look like? Ta
Duck Truck
1,203
1,226
UP North
Hobby 725
Keep your hand on the green button to fill
can be up to 10 seconds before the pump starts to run
The first time I thought the pump was faulty and kept taking my hand off the button
Got nowhere
scotty1
254
38
Kent
Wildax solaris xl
Fletton
1,531
2,501
Lincolnshire, UK
Knaus Sky I Plus 650LG
First MoHo - April 2015
Got nowhere
I fill often.... and if the pump has not been used for a while.. it can take a lot longer before filling commences.. especially if tanks are some distance from pump....
Apr 27, 2016
6,874
7,998
Manchester
A class Hymer
Since the 80s
You've probably worked this out already, but just in case you haven't noticed, looking at your pictures, your adaptors fit onto a large coarse thread (1 3/4 inch Acme thread). The adaptor in cronkle's link is a smaller finer thread.
So you'll need an extra adaptor for that Spanish adaptor. The same site sells it, you could get them both together.
http://www.autogasshop.co.uk/134-ac...hread-ideal-american-rv--westfalia-1020-p.asp
The Acme thread filler was used in the UK many years ago, but has now been replaced by the bayonet type. The only place I've seen an actual Acme Thread filler recently is the Capellen filling station in Luxembourg. Good fuel prices make it very popular to neighbouring countries, or to fill up if you're going in that direction.
