Hi All,
We're heading off to Europe in a short while for several months, mostly in Scandinavia. I'm thinking two thirds of the overnights will be off-grid with a third spent on campsites. With this in mind, would it make sense to replace the existing 6 Kg calor with two 6 kg Gas-it bottles which can then be filled from a petrol station? It seems LPG is far more likely to be available than calor. For the times we will be on a campsite we can use EHU.
We would like to fit the gas filler on the inside (don't want to drill a hole in the side of the van) of the gas locker, but I've heard stories that some petrol stations will stop you from filling up, if that is the case, is that right?
Interested to hear any alternatives you may have.
The gas will be used to heat water and the van (it could get pretty cold in Norway!) and provide for cooking.
We had entertained the idea of fitting a diesel heater, but decided against drilling holes in the newly purchased van.
