thanksI wouldn't recommend you use Butane. There's been an awful lot of bad gas causing blockages to fridge and boiler jets. I've had to strip out the fridge burners so now on propane and all ok. We've also had butane freezing overnight.
A new bottle full of propane is available at about 30 euros plus the regulator.
Any dealer really as long as you get one. Good luck.Tha
thanks
Do you suggest we get it from the supplier mentioned above?
Where is it available from? We are in Segorbe near Valencia but it is Sunday....I wouldn't recommend you use Butane. There's been an awful lot of bad gas causing blockages to fridge and boiler jets. I've had to strip out the fridge burners so now on propane and all ok. We've also had butane freezing overnight.
Thanks- whar about the regulator though?Most Ferreterias (hardware shops) have gas bottles to swap
Jaws, if we go to this depot will they sell us an English calor gas Or do we still need a regulator and pigtail hose etc?Well it does depend on where you are.
If you are near Benidorm there is a big gas depot next to the out door market area that does it
It's a Spanish depot, they won't do calor and I would expect that they will only sell the Spanish bottles of propano and doubt they do regulators or other bits. It's just a bottle depot. There is a shop opposite the Raco site in Beni that would fiix you up with adaptors and hoses etc.Jaws, if we go to this depot will they sell us an English calor gas Or do we still need a regulator and pigtail hose etc?
Jac Sprat can you clarify what’s regulator you are using ?
Is your regulator on your calor bottle or do you have a hose from the bottle connector to a bulkhead mounted regulator.
If The first then you need a Spanish regulator that can be jubilee clipped to the hose.
if the latter then you need the correct pigtail and a jumbo bottle adaptor. This clips to the top of the Spanish bottle and the hose has threads at both ends that attach to the connector and your bulkhead regulator.
Obviously you still need to source a Spanish cylinder.
Some people with a Spanish cylinder use a cylinder mounted regulator and back feed into their system via a bbq point ( I’m not getting into the discussion whether this is good practice.)
Which don't appear to be refillable cylinders but a Calor propane cyl. Therefore you will need a spanish repsol or cepsa cyliner , with black band around & a regulator to connect to the existing orange pipe .although spanish regulators the pipe pushes on ?View attachment 364366
this is what we have.
Thanks we are visiting Repsol, the gas company today, phoning first. Someone on our site had his converted by them.Which don't appear to be refillable cylinders but a Calor propane cyl. Therefore you will need a spanish repsol or cepsa cyliner , with black band around & a regulator to connect to the existing orange pipe .although spanish regulators the pipe pushes on ?
Buy an old butane or a propane one from the nearest market or car boot sale. Going rate around here is around @€10 for an empty one. . Then just swap it for a full one at any Repsol or Campsa garage or any camping site. Swapping for a full one "ie refilling" is around €17.
