So how do you know how much payload you are allowed?
I note you havent got a van yetSo how do you know how much payload you are allowed?
Have you read Jim's Buyer's Guide? If not do so as it's free to subscribers and will definitely give you a lot of info which you can then regale your hubby with!and why is it so important? (I told you it should be my husband asking these questions!) So a 3500kg van and then I keep hearing about payload. What do we have to be careful about? Thanks
Take your van to a public weighbridge and ask for a readout slip to include both axle weights and total weight. .So how do you know how much payload you are allowed?
Still confused...is the 2900kg an empty base van weight?Take your van to a public weighbridge and ask for a readout slip to include both axle weights and total weight. .
If your van has a max weight of 3500kg it's the difference between 3500kg and the weight on the readout slip.
When loading, the axle weights for both front and rear axles combined cannot exceed the vans maximum weight and neither axle can weigh more than the max stated on the VIN plate
Example....
Weight at weighbridge = 2900kg
Max vehicle weight (from VIN plate) = 3500kg
3500kg - 2900kg = 600kg payload.
The payload includes you, passengers, towbar, awning, solar panels, extra battery, food, clothes etc
you will continue to be confused until you spend some time reading Jim write up on payloads and that will explain all you need to understand. it is not a subject you will get your head around from random answers however accurate they are.Still confused...is the 2900kg an empty base van weight?
Yes, but the quoted figure was just an example.Still confused...is the 2900kg an empty base van weight?
No, unless uprated springs and tyres are fitted the axle limits remain as they were.So to throw into the mix...
By upgrading from 3500 to 3850 by re-plating, does that mean the front and rear axle loads increase accordingly ?
Can’t see anything on this. Even the SV Tech website isn’t clear
Depends you have to do the calcs to determine what the additional load at a distance from the rear axle adds to it and what it takes from the front.Tbh just had a nice surprise in that a bloke on here with exactly the same van spec kindly weighed his van and let me know the figures which showed overall weight at 2960kg with rear axle at 1220kg and front axle at 1680kg
ok, the remaining payload of 540kg isn’t amazing (against 3500 max) but what great is that the rear axle weight remaining leaves me with 780kg to play with (max being 2000kg) as long as I replate to 3850kg
enough for a substantial scooter on the back methinks
I think !
you lost 60kgs somewhere, front and rear weights add to 2900kgs total weight was 2960kgs. also i know the van is a pvc but the rear axle seems light at 1220kgs,Hmm, uneven loading
I haven’t reached that chapter yet ! ?
You can only uprate to the axle max without modification.
