What can I keep in the gas locker? Possible daft question! (3 Viewers)
Oct 19, 2013
450
736
East Yorkshire
Elddis Autoquest 115
Few years
Hi all.
Just had gaslow moved to my new van and the filler cap properly mounted in the body work so no need to open it to fill up.
The locker is quite spacious and I am thinking of using the space to store my EHU cable (in a bag) and a couple of bottles of green toilet fluid...
Daft question maybe but is there any reason I shouldn't?
Richard
Nov 6, 2013
3,201
229,675
East Sussex
Hymer B574DL
Since 2011 (tugger for 20 before that)
I can't see why not. Sounds like a good idea to me. Unless someone else knows better.......:rolleyes:
Feb 16, 2013
19,735
52,042
uttoxeter
ambulance conversion
50 years
As long as you don't block the holes in the floor no probs
Feb 9, 2008
4,094
5,911
SW Scotland
LP Coachbuilt
I keep all sorts of odds and ends in there, plus the gas bottles.
MillieMoocher
1,118
10,640
West Yorkshire
Autosleeper Kingham
40 years under canvas: Motorhome 2016 To 2020
I keep a bottle of blue and a bottle of green bog fluid in my locker with the Gaslow, and a big funnel thing for adding adblue. Seems a good idea, as there are the vent holes in the bottom and so if the bottles leak, they don't end up in the van..
Apr 11, 2015
5,417
55,248
hull
Laika Ecovip 300
I keep a hammer well wrapped and jammed so doesn't bang on bottles, and a tow rope in mine.
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
I keep about 20 cans of ex Russian Army issue anaesthetic gas in there for when I'm on an aire and the holiday money's getting a bit short.
Oops, what a giveaway.
May 29, 2013
2,599
19,252
Tyneside
Chausson best of Flash 10
Several years now
We fill ours full of all sorts of stuff, being careful to not block the vents in the floor of the compartment. However, none of it can produce an electrical spark or have any form of ignition. IE it is all inert.
Look at it this way, if there was a leak of gas from your bottle and somehow it built up in the compartment you would not want anything to produce a spark at that point.
I am amazed that some vehicle alarm fitters actually put an electrical switch on the inside of the compartment door. If you had gas in there at the right concentration and you opened the door with the switch energised, then you'd be lucky not to cause an explosion.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
No room for the gas :LOL:
32,662
66,584
I understand Dave N's point and you need to decide what you're happy to do yourself.
The gas locker in our PVC is massive so I put in stuff that isn't going to cause a spark and make sure it's secure so can't move around. On the base in front of the cylinders I have plastic grids (upside down shallow plastic baskets) to raise stuff about an inch above the bottom drop vents so any gas gathering down there isn't impeded at all, and make sure that there is room for any escaping gas from the top of the cylinder/pipes to be able to easily drop down without being hindered.
I do NOT use large material bags to put items in as they could act as 'balloons' and hold back any escaping gas so if I DO need to put a large item in a bag I use a netting/mesh type bag - for example the hook-up cable mentioned above is a prime candidate for a netting bag, rather than a material bag, as a netting one serves the same purpose but gas can't get trapped in it. I also put in my gas equipment such as spare small canisters for the suitcase stove and the stove itself (it has air holes/gaps in the case to prevent gas gathering), I have a small rack on the door itself for cylinder connectors etc (easy to get at) and a hook-on tub with hose connectors in, both of these have holes in the bottom and the contents are not tightly packed. There is quite a bit of space above our cylinders so I have an elasticated net fitted horizontally (the type that you'd use to hold stuff onto a motorcycle rack) well above the outlets/taps and kept taught - this allows me to store flat and light stuff there such as a narrow water container, funnel and short filler pipe with rubber end on for a tap.
Techno
Jul 28, 2010
15,475
20,756
May 2010
No risk they are sealed and only magnetic
Aug 30, 2012
4,270
11,305
Home of the war horse
burstnar T640
Just had a look in ours
Pliers
Tent pegs
Small hammer
Spare bin bags
Short hook up cable
Extension lead
WD 40
2 broken gas bottle gauges
5 tonne bottle jack and handle
O and 2 gas bottles God knows what's behind them
11,954
16,570
Consider caravans with a front gas locker: they have excellent drop ventilation and no restriction on what can be stored.
Dec 18, 2010
885
929
Norfolk.
Autotrail cheyenne
2008-20??
When in europe I carry my warning triangles in the gas locker as it is on drivers side (nearside when driving on wrong side).This means I can get to them without getting killed.My garage door is the other-side.(y)
Chris
21,056
278,914
10 years
I always forget how to open our locker.
There is a lever somewhere...
eddie
8,159
41,274
Taunton Somerset
RV
since 1989
Perhaps you would care to explain how that could happen? That incorrect statement could cause concern to many people
2,599
19,252
Tyneside
Several years now
Sorry Eddie, it is not an incorrect statement. This is my specialist subject.
If you have an area, be it enclosed or open with a concentration of gas (between it's lower explosive limit and it's higher explosive limit) and there is a spark which contains enough electrical energy in that gaseous area then it will explode!
That is why houses are reduced to rubble by gas explosions, a gas concentration occurs then someone switches on a light or a timer clicks over.
A standard 12v DC supply, through a switch which changes state, will easily ignite gas. Of course it rarely happens, but it certainty could in the right (wrong) circumstances.
Steve N Tracy
1,235
3,728
Southampton
4 Years
I thought most alarm external modules were sealed reed switches ? so no spark.
