just had a call for me to sort out a broken ford transht wet belt this will be the 5th i have done ....got to love a ford lol
NOCO Boost X GBX45 1250A Jump Starter Power Pack - 6.5L Petrol, 4.0L Diesel | UltraSafe: Spark-Proof & Reverse Polarity Protection, 60W USB-C Power Bank, 12V Battery Booster for Cars, Motorcycles & More £119.48
BITS4REASONS NEW MODEL MAYPOLE MP374B 200-250V 16A UK HOOK-UP LEAD 3 PIN/MAINS ADAPTOR CARAVAN MOTORHOME TRAILER CAMPING CAMPERVAN WITH EASY FUSE REPLACE PLUG £11.99
Cadac Safari Chef 2 Pro QR BBQ - Black £139.95
Bosch H7 Maxibox Halogen Bulb Set for Car Headlights and Lamps, 12 V - Socket Type PX26d - Spare Bulb Box Containing the Most Essential Bulbs and Fuses £10.28
My Ford 2.2 diesel engine has a cam chainjust had a call for me to sort out a broken ford transht wet belt this will be the 5th i have done ....got to love a ford lol
yes but retired at 40 ,12 year ago and got into property but i cant help myself i like workin on tricky shty stuff now and then keeps the brain ticking good.yeah it can write the engine off depending on the worth of the van if its a beat up work van u mite be better off cutting your lossAre you a mechanic by trade or just a friend everyone wants
Does it wreck the engine when it breaks ?
..lol u were lucky ..keep ya oil changes up and go well under the time and millage for a belt changeFunnily enough a couple of months ago i read on here about transits wet belt(didnt know ours had one) but apparently it had ,i immediately got it booked in and changed120,000 miles, £900 i think its cos its 2 litre and not2.2, so thanks to this site i got it done![]()
From what I've seen and read - there is a lot of this on Youtube, mostly by mechanics - its not just the belt failing in the conventional way, its also that as the belt naturally degrades, the inevitable crumb gets into the oilways with predictable results. We know that car makers no longer want their products to last but some of these wet belts arent even making it out of the warranty period.There seems to be a bit of a downer on Transits with "Wet Belts"........ Not on here I might add, but certainly on other social media channels. Lot of scaremongering going on.
There is no issue with the wet belts as long as you follow the correct guidance by Ford, regarding oil changes and belt changes.
I heard of a couple where they had done nothing really, splash of cheap supermarket oil for top up, then run the engine through 150,000 miles plus, and wondered why the belt gave up the ghost.
I purchased my Transit Custom with just over 30,000 miles on it, and immediately had the belt changed so I could start from day one with it, despite knowing that the previous 30k had been treated with the recommended oils and changes (Was my son's van used for his business), he is a stalwart of the Transit MS-RT, and does follow Ford's guidelines, as do I.
Look after them, and they will serve you well.
I bet there are a few on here with good miles on them, that have looked after them well, and not had issues.
That only works if the manufacturer gets it right.There is no issue with the wet belts as long as you follow the correct guidance by Ford, regarding oil changes and belt changes.
The engine was jointly developed between PSA (Citroen Peugeot) and Ford, because Ford was so useless at solely developing and producing one of their own.My Ford 2.2 diesel engine has a cam chain
The engines are so fantastic Peugeot buy them for the Boxer... Or did![]()
The usual reason for joint collaboration between vehicle manufacturers is cost, why invent the wheel twice, and when it comes to body shells, two different companys, different models, but can duplicate on a lot of the crash tests to ensure that the body survives ok.The engine was jointly developed between PSA (Citroen Peugeot) and Ford, because Ford was so useless at solely developing and producing one of their own.
I would have thought the alternative to a wet belt would be a dry belt which has the same weight and noise advantages, not back to a chain. I agree that letting the accountants rule businesses is the problem but I can see the need for reducing pollution and emissions.From what I've seen and read - there is a lot of this on Youtube, mostly by mechanics - its not just the belt failing in the conventional way, its also that as the belt naturally degrades, the inevitable crumb gets into the oilways with predictable results. We know that car makers no longer want their products to last but some of these wet belts arent even making it out of the warranty period.
I suppose thats the problem with an industry controlled by accountants and constrained by dubious environmental regulations. Even recent camchains are no longer a safe bet as those that decide have reduced the weight of the chains for "to reduce emissions", even previously bullet proof companies like Toyota are being affected.
Ford have produced some good engines in the past, it comes down to the finances nearly all manufactures do joint efforts on engines and other parts.The engine was jointly developed between PSA (Citroen Peugeot) and Ford, because Ford was so useless at solely developing and producing one of their own.
Fords collaboration (dependence) on PSA (Stellantis) goes back to the 70’s/80’s.
If the belt snaps you can get away with just a new cam carrier which goes above cylinder head.Does it wreck the engine when it breaks ?
Or buy a Fix It Again Tomorrow! Hardly paragons of reliability look at the recent posts on steering rack electrics problemsFix Or Repair Daily
Ditto my Ducato. FordMy Ford 2.2 diesel engine has a cam chain
Oops - sorry - Ford Puma. Doesn't do to get your Pumas and Pintos confused . . . .
Because all the emissions hoops that you have to jump through, mean that the resistance of a dry belt is too great.Wet belt system is the worst design ever, why?
We use essential cookies to make this site work, and optional cookies to enhance your experience.
