Water sensor probes AT Cheyenne 2004 (1 Viewer)
irnbru
13,514
31,142
Glasgow
Benimar 264
11 yrs
Please can someone tell us how do you get to the probes on this model? Does the tanks have to be dropped? Both water levels dont seem to read correctly. Have tried to clean with coke but no use.....and can anyone explain the control panel. When the waste level reads 100 and you press the middle button and hold it in for 5 secs it then reads waste level 2 =50%
So then if you turn it all off and on again it still reads the latter...As if I have changed it...puzzled.
Nov 5, 2013
3,111
97,947
Shropshire
Carthago chic e-line
When we went on the factory tour I asked where the fresh water sensors were on a Savannah as they had a base chassis there with the water tank fitted
...........they couldn't find them!
To be quite honest I think it's a case of water in = water out! I replaced the waste tank sensor and it only lasted 6 months.
Notoriously unreliable.
irnbru
irnbru
13,514
31,142
Glasgow
Benimar 264
11 yrs
Where is it Richard? How did you replace it?
11,934
9,106
Think he is trying to say don't bother Sandra :D You should be able to get to them through the big unscrew bung ;)
terry
23,836
72,577
The control panel is a universal thing that is used on lots of builds.. some will have twin waste tanks.. There is also provision on some to choose internal or external pumps !
irnbru
irnbru
13,514
31,142
Glasgow
Benimar 264
11 yrs
terry
But where is it?
Thanks that probably explains the control panel
R
Robert Clark
On our Bessie, the big screw cap was accessed via a lift up panel in the floor.
With the cap removed you could see and feel the sensors
The waste tank screw cap could only be accessed from under the van. With the cap removed the sensors could be felt.
We found that by cleaning both tanks with 'proper' Elsan tank cleaning fuid that both sensors started to work properly again
To prevent further problems we always empty the fresh water tank between trips and use Dish'n'treat which is a washing up liquid that is also a tank and pipe cleaner
11,934
9,106
Hi Sandra it will have a couple of wires attached hanging down from the top of the tank -If your large bungs are at the bottom of the tank you can unscrew it and it should give you access to it -if not drop tank to get at it
-Better to listen to your pump tone and you will hear when it's getting close to empty (y) filling wise stick hose into filler and when water comes out of filling hole, think it's full:LOL::LOL:
Nov 5, 2013
3,111
97,947
Shropshire
The waste sensor was a float switch,push fit into the side of the tank.Ours was a 2010 van so might not be the same but was accesible from under the van.If you find it make a note of which way up it goes,ours had a flat side to it.
If you find it make sure your waste tank is empty before removing it. :LOL:
Gellyneck
9,255
18,370
More than toes wet now!
No idea where they are Sandra but have you changed your van?
irnbru
irnbru
13,514
31,142
Glasgow
Benimar 264
11 yrs
No and we aint gonna :) ItsAlans MH that has the problem but since im on the forums so much Ive been given the task of getting the info :)
Gellyneck
9,255
18,370
Ahhhh.(y)
