The Tank sensors probably need calibratedWater pump wont work unless water tank showing 70% plus full. Anyone have an answer - other than keep filling the tank. Thank you.
Thank you. It’s going to dealer next week. Will get them to sort it.The Tank sensors probably need calibrated
Loads of manufacturers use submersible pumps the way they do is probably designed for caravans where the tank is outside. About time they designed a Motorhome rather than bolting a caravan onto a cab.They use a submersible pump and the sensors are not the best. Bailey are working on rectifying them.
Thank you all for the information. I really appreciate it. This is our first MH, and we've only used it twice up to now. Very much beginners, and maybe a bit too old to be on top of the technology! It conked out on the A30 coming home from Cornwall and had to be AA'd to a Ford commercial dealer. Turned out to the fuel injectors.Loads of manufacturers use submersible pumps the way they do is probably designed for caravans where the tank is outside. About time they designed a Motorhome rather than bolting a caravan onto a cab.
I think these fuel injectors are a well known problem on the new fords. Hopefully they replaced them all and not just the faulty one.Thank you all for the information. I really appreciate it. This is our first MH, and we've only used it twice up to now. Very much beginners, and maybe a bit too old to be on top of the technology! It conked out on the A30 coming home from Cornwall and had to be AA'd to a Ford commercial dealer. Turned out to the fuel injectors.
