Water pump doesn't operate with shower (2 Viewers)
klaatu
1,993
2,793
Vienne, France
Globecar Summit 640
Since 2014
I replaced our water pump, which was leaking badly and not pumping very well, with a Shurflo, which works much better - via the taps. However, turning on the shower does not cause the pump to operate. It did with the old pump.
Our workaround is to simply turn on a tap very slightly, to cause the pump to turn on, and then the shower works fine - as long as we leave the tap slightly on. Could it just be that the pressure switch on the pump needs adjusting?
Steve
Hymie
810
1,005
Classic Hymer B564
Since 1981
Steve, I have a similar problem at the moment, shower will only run if I turn the bathroom sink tap on.
I don't have time to worry about it at the moment, will probably fix it while we are in France in October but will follow this thread with interest.
Hymie.
2,335
10,105
Hi Steve
you have replaced a submersible pump with a Shurfo ..? I suspect your shower tap micro switch is u/s ..
A submersible pump works by a feed from the tap microswitch.. each tap has a switch.
Normally a Shurflo is fed directly , not via tap micro switches.. it doesn't need them.. it has a pressure switch that turns the pump on when it senses low pressure..
Surflo pumps have a bigger current than submersible ones, and will eventually burn the contacts of the micro switches.
A solution would be to disconnect the wires at the shower micro switch and connect them together with a connector or simply twist them together and insulate.
Best solution is to remove all micro switches and just have a feed to the Shurflo via the on/off pump switch.
klaatu
klaatu
1,993
2,793
Vienne, France
Globecar Summit 640
Since 2014
No, the original pump was also pressure operated, there are no micro switches on the taps or the shower.
Steve
2,335
10,105
Steve
ok.. forget what I said..
try lowering the pump pressure switch setting with the shower tap open.. (adjust the screw on the pressure switch anti clockwise ) do it gradually, 1/4 turn at a a time
43,330
49,446
Before you go adjusting anything try the shower tap with the hose or spray head disconnected.
Could be too much back pressure with the spray head attached.
Once proved either way then start fiddling.
If it is the head causing problems you may need one with bigger holes.
Adjusting the pressure switch to lower the cut off/in may mean the pump runs for an excessive time after closing the other taps.
klaatu
klaatu
1,993
2,793
Vienne, France
Globecar Summit 640
Since 2014
Yes, I've already tried it with the head off - same result. I'm going to have to try to find a screwdriver short enough (or an offset one) to adjust the switch, as the adjuster faces the floor and there's not a huge gap.
There's an accumulator fitted, if that makes a difference, and I've read that these need to be set to the correct pressure, but there doesn't seem to be any way to do that with this one, it only appears to have an inlet and outlet for water.
Steve
Jan 28, 2008
10,117
18,382
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
the accumaulator shouldnt make any difference ive not looked at a caravan type but domestic ones have a tyre valve on the top to refill the bladder inside
i cant see how the pump doesnt kick in with an open end on the showerhose i assume the water gushes the slows to nothing?
is it the same on hot and cold to the shower?
it sounds like a dodgy pressure switch but it works on the other taps only thing i can think of is the pipe work to the shower is blocked and holding pressure in the main pipework and the initial flow is what creeps past and is relesed when the tap is opened
is it possible a washer was pushed into the pipework while changing the pump?ive had that before on domestic
possibly it will be a case of opening the pipework further back towards the pump in stages to find out at which point it works
just thought its not the washer in the tap end of the hose blocking the flow?
10,117
18,382
Renalt burstner
i wouldnt adjust the pump till i was sure the pipework is clear flowing not sure of your set up but back filling from a hose with the pimp dissconnected will prove its clear
2,335
10,105
klaatu
klaatu
1,993
2,793
Vienne, France
Globecar Summit 640
Since 2014
As Jim points out, with the tap open very slightly to activate the pump, the shower then works fine, so I think the pipework to the shower must be clear.
Steve
klaatu
klaatu
1,993
2,793
Vienne, France
Globecar Summit 640
Since 2014
Jim, I owe you an apology. I was about to have a go at adjusting the pressure switch, but I found that the shower had started working. Further investigation revealed that the taps DO have switches on them, so presumably the shower does too and the switch has gone intermittent.
I had foolishly assumed that the pump was pressure operated, as the original wasn't submersible either. From what you say, it seems my best way forward is to change to a pressure operated system by bypassing the tap andf shower micro switches. I'm not sure at the moment how I get to the shower switch, though.
Steve
2,335
10,105
Glad you solved the mystery .. yes, I would get rid of the micro-switches and associated wiring. Less to go wrong.. KISS
There may be an access hatch behind the shower taps.. in a wardrobe/cupboard.. ? ..
