Water pipes (1 Viewer)
AUDREY CLARKE
Plymouth
High top
Newbie
Hi, we're newbies going off tomorrow to try out Motorhome, didn't realise the pitfalls of cleaning the water pipes, what's the best way to ensure germ free water?
Feb 9, 2008
4,093
5,910
SW Scotland
LP Coachbuilt
Since 2008 after caravanning for 20 years
We don't drink the water from the tank, use a container filled fresh each day.
Feb 21, 2016
4,920
29,544
Uk
C class
Since 2017
How long are you away for?
43,329
49,445
We always drank water from the tank.... Not so much as a sore throat in ten years.
Tap water contains chlorine and as long as its not left unused for weeks is safe to drink.
But it depends on your constitution.... I've drank from rivers, puddles, water butts etc as a kid and built up a resistance.
Many remote small Scottish villages are fed directly from an open reservoir and could contain anything from dead trees to dead animals... Nobody dies drinking the water.
Pamper your stomach and you'll suffer for it
Jan 8, 2013
8,490
11,527
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
Whos told you to clean the pipes or to ensure the water is germ free? We've been drinking the water from a tank filled by a hose for years - never a problem. Its nicer if you drain the old water off and put some fresh in before you leave.
Jul 12, 2013
3,872
5,275
The City of Henlow
Adria Supreme
Since 1980
When it comes down to it, we hardly ever drink tank water direct. Tea or coffee is made with boiling water and should we want to drink tank water, we run it through a "Nature Pure" built-in filter.
In truth we have rarely had a problem with drinking water going bad but when it does, it is not always easy to eradicate the smell of bad eggs which we got this year in our shower and bathroom taps. It finally went away after running very hot water through the two outlets. I can confirm that taking a shower that smells of stink bombs, loses most of its magic.
Terry
11,932
9,084
Lincolnshire
Can't remember ;)
If you are worried add a mug full of bleach as you fill your water tank,flush it through all your taps and leave for a few hours or overnight.No longer,then empty your tank flushing through all your pipes ie turn taps on :D refill and flush your tank a couple of times
Right now for my hard hat .....from the don't use bleach bigrade :D2
Aug 2, 2017
710
671
South Kent Coast.
Since 2004
Our Terry is going for his hard hat because the water from your fresh water tank goes into the water heater and the manufactures don't like bleach in the heater coils. (y)
scotjimland
2,327
10,082
A Woosh bang
As a new owner, you want to ensure the system is clean, so as @Terry said ... ( don't use thick perfumed beach, just thin cheap bleach )
and after that there is more than enough chlorine in your tap water to keep the tank and pipes clean...
and PLEASE do not buy bottled water .. not only killing the planet but you are more likely to get germs from it than your tank... unless you are outside the EU and the water supply is suspect..
and don't waste money on Milton.. it is just very weak bleach with salt .. It contains 1% sodium hypochlorite (NaClO) and 16.5% sodium chloride (NaCl; common salt).
Cheap thin Household bleach is 5% sodium hypochlorite.
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Used it once a long time ago. Never did get rid of the taste.
scotjimland
2,327
10,082
A Woosh bang
perhaps you did it wrong or used thick bleach .. but there should be no after taint if done correctly and flushed properly
water systems in factories and offices and routinely chlorinated using sodium hypochlorite.
chlorinated water is also used widely in the food industry in hydro-wash flumes for cleaning fruit and pre packed salads..
How Is Your Produce Being “Washed”?
The most common type of sanitizer used is , in the form of sodium hypochlorite (in granules, tablets or liquid). In addition to the dosage amount, the amount of free chlorine, pH, temperature and the amount of organic matter (what is in the water in addition to the sanitizer, e.g., soil) all impact the effectiveness of the sanitizer. Other types of sanitizers used include Broken Link Removed, ozone, aqueous chlorine dioxide, etc. New types of sanitizers are also currently being researched, such as neutral electrolyzed water and acid electrolyzed water.
https://www.theproducenerd.com/2016/07/how-is-your-produce-being-washed/
tonka
10,830
21,528
Cannock, Staffs
A class Burstner 800
Since 2000
18 years of motorhoming... 6 vans (i think)...
Used water from several countries within Europe and Morocco..
Never cleaned a pipe or tank in my life.. Still here :D
Just give it a good flush a few times, we dont drink direct from the tap but use water once boiled.
Lenny HB
53,431
150,007
On the coast in West Sussex
Hymer B678 DL
I thought it was only beer pipes that need cleaning.:)
Always drink from the tank, do use a cheap inline filter inline with kitchen but that is more for taste than safety.
Flush the system once a year with white wine vinegar but that is to clean chalk build up in the boiler.
Jan 12, 2016
300
2,063
Amble
adria izola
since 2014
Always use the tank, Just flush every now and then ,
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
since 1999
I was, admittedly, less clued-up on such matters in 1983 :D.
Jul 12, 2013
3,872
5,275
The City of Henlow
Adria Supreme
Since 1980
For a true gastronomic experience, try making a cup of tea with water that passed through a Milton cleaned pipe. After a complete water change x6, ours still tasted awful.
I have heard that in some countries where Vodka (or I suppose Gin) is very cheap, it can do a sterling job of cleaning the pipework. To check its effectiveness, you should take several sample for drinking. Just to check their is no residual taste.
TerryL
6,184
8,186
North East
Low Profile
Just use normal common sense when refilling the tank i.e. clean/disinfect any supply tap you are not 100% happy with to avoid transferred infection. Plenty of anecdotes of folk rinsing their toilet cassettes from the drinking water tap!
Some recommend using a food-grade hose but we've always used a (dedicated) garden hose. Whatever, flush the hose through first before filling.
Drain down after every trip, or at least drain off any "old" water before refilling for a new trip. If it's been a while since last used I tend to do a full system flush before final refill.
Don't bother with additives etc. unless you've got a problem. Remember, though, nasty niffs are more likely coming from the waste water system, which is a different subject.
We only use bottled water for cold drinks, because we can cool it in the fridge. Hot drinks use the tank.
In 10 years never had a problem (well, that could be related to bad water).
Apr 27, 2008
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
Bottled water is full of bugs which is why they carry a warning not to use for babies. The bottles are useful though, fill up from tap and put in the fridge.
