Water heater pump keeps running (1 Viewer)
Gary and Sarah
RV
I'm a newby
We have just come back from our first trip away in our Cheyenne 632 (2004) no problems except that the heating pump wont stop. We have disconnected it by pulling a wire off of it in case we are damaging it. Does anyone know what we've done wrong? Many thanks.
tonka
10,834
21,544
Cannock, Staffs
A class Burstner 800
Since 2000
Most likely a leak somewhere.... Does not have to be a big one and could be just a loose connection.. Also if you have a screw on filter make sure that is OK..
Welcome to Fun..
Feb 16, 2013
19,738
52,049
uttoxeter
ambulance conversion
50 years
What do you meen by heating pump? Do you meen the water pump , which is what tonka has replied, or the boiler , two different things.(y):)
tonka
10,834
21,544
Cannock, Staffs
Since 2000
Good point..I am assuming a water pump.. As that's most likely and the only ones I know about.. :)
Oct 25, 2015
456
283
Devizes
Bailey 79-4t
Since 2016
I have had this problem and it's most likely a collapsed diaphragm in the dump valve which causes a small drip leak which drops the pressure enough to kick start the pump
