Water fill up hose pipe (3 Viewers)
17,635
43,369
always use food grade for fresh drinkable water. 2 10m lengths of hose with a coupler then you can adapt to the varying needs
18,035
48,145
I use a flat hose sold on a reel for use with boats - I got it at a chandlers. It is about 25m long and is long enough for almost every situation. Not cheap, £25 or a bit more but it takes up very little space.
Just run the water through the hose for 15 seconds or more before filling the tank and you don't need to use food grade tubing.
1,930
3,241
West Yorkshire
EuraMobil Activa 820HS
I had a Brunner hose food grade on a reel which packed flat and could be used without unraveling it all from the reel.
It was crap.
Holiday was half over before the tank got filled.
I sold it on eBay.
I now have 10m of blue food grade hose and I've also got 30m of expandable hose which is also food grade rated and is ace. It expands on filling with water and collapses down so small when the tap is turned off that it will fit in a pirex bowl.
8,491
11,530
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
Why food grade? Isn't it contaminated the first time you use it? Is the plastic pipe to the tap food grade?
Any water you drink tends to be boiled first any way.
25 Mts good quality, non kinking hose.
Been using it for 25 years and I'm still KO?????
13,090
101,509
Bolsover, Derbyshire
Hymer S800
not long enough
we don't drink ours, so use a standard hose reel, 25 m I think, plus we have another shorter length and a male / male hozelock connector to join together, we have plenty of room though so space not a consideration
sdc77
3,244
4,550
Weardale, Co Durham
We don't drink from our van .. weve got a longer hose .. about 10 metres and a 2 metre one. Don't think either are food grade.
We use bottled water for the dog (and us if we need fresh cold water)
11,844
14,080
I carry 3 hoses, all food grade. 2m, 8m and 20m. They can be joined together if necessary. We use the tank water for making tea etc, but will drink water directly from the tap on a site/aire rather than the tank which in any case tends to be tepid. Only rarely need to buy bottled water which we tend to avoid anyway because of its high cost, bacterial content and other toxins which can leach from the plastic bottle. (Not considered a health risk in most people but can be dangerous in the very young and old)
Take adequate precautions with site/aire taps as some people do disgusting things with them, including rinsing chemical loos.
1,930
3,241
West Yorkshire
Personal choice I suppose.
There's different chemicals used for the PVC in a typical garden hose to that of food grade/drinking water grade hose.
Most of which is flushed out on the first use (into the tank) but if any water is left in the coil between usage, some chemicals can leach out by osmosis.
Plus, there is a taste of plastic.
Those are the reasons I got food grade/drinking grade.
As for the pipe to the tap - that would depend on who's fit it. If it was a reputable motorhome manufacturer within the past ten years or so, I'd say yes. Same as the tank, same as the taps.
However, like you say, if you've been using it for the last 25yrs and you're ok, it's like smoking - each to their own.
Enword
1,900
7,999
Devon
Coach Built
Race van conversion for years
We always use food grade, the boss cant taste it if we use garden hose but I can even if its boiled, she reckons Im just a fuss ass! :whistle:
DanielFord
3,020
3,086
Like many, we don't drink from the tank, so have a regular 10m hose which we got from Dyas, the advantage is, it is one of those that doesn't need to be fully extended to be used, unlike a flat hose (which it seems most food grade ones are).
We carry 3 5 litre bottles of drinking water in the van for consumption, this has proved more than effective for our needs.
43,337
49,538
How often do you clean and thoroughly dry the internal surface of your food grade hose ?
Water left in the hose will stagnate and harbour bacteria.
Food grade means it wont leach chemicals from the hose material, it doesnt mean its bug free.
I always use garden hose and havent suffered any ill effects in 9 years.
11,731
13,711
Where did you get the food grade expandable hose please? Seen plenty about, but never food grade.
Cal54
3,807
62,076
Southport, UK
Leisuredrive Renoir
Since 1996
Just use the expandable wonder hose which basically looks like/is silicone. Having seen the black growth inside my previous food grade hose when not used for a while I prefer to change hose regularly. Don't drink the water direct from the tap anyway. Also the small space taken up by my expandable hose is a bonus in a PVC.
Badknee
7,408
413,071
notloB
Vantage Neo
Living the dream.
I attach a small submersible pump to one end of our hose, bucket of water with purex tablet in it. Put pump and other end of pipe in bucket and flush through for a few minutes.
9,551
32,145
sleights
c class
We have a flet hose on a reel and shorter about 3m garden hose and find we only use the long one 2 or 3 times a year. Neither are food grade just let the water run a few seconds the contact time with the plastic is so short I can't believe it could do any harm. Would be interesting at a funster meet to have a blind tasting of water through the 2 types of hose I would be very suprised if there would be any difference and would like to challenge those who think they can to tell the difference!
307
295
Knaus Sun Ti
Since Dec 2009
We have a Nature Pure filter so don't worry about the type of hose used for filling and can drink the water from the tank with no problems.
Same for us!
We have a 10m hose - if thats not long enough we use the watering can!
We used to carry another longer hose to connect to make an extra long hose but didn't use it so its now in the shed :whistle:
glenn2926
3,326
13,619
Gods country
Chausson
newbie hired 3
Why food grade hose? I don't think food grade hose is used to bring the water to the tap. Either in your own home or to the tap on sites etc. So just wondering why food grade is used for the last couple of metres?
934
1,331
Lincs
Generally the pipe bringing water to your own home (at least in more modern homes) will be made of polyethylene which is classed as being food safe.
Some plastics leach chemicals more than others which is why not all of them are classed as food safe.
860
3,706
Cromer norfolk
Bailey approach 745
since 2002
Used yellow garden hose 10m long for the last 14years and drink water from the tank boiled and cold never had any problems. And do anything from 80-180 nights a year.
Shrimp
May 27, 2015
3,988
33,501
Bedfordshire, UK
Hymer B584
Long time
We use a flat hose on a reel with various adapters. We don't drink the MH tank water, it's used for washing, washing up & the loo. We have a nylon container for 'drinking' water, tea, dog, etc.
43,337
49,538
But some old rural properties can still have lead pipe.
We have blue poly up to the stop tap in the garage, copper into the house with a 1-3/4" iron pipe riser to the cold storage in the loft.
The iron has been there since 1922 and must be full of all kinds of nasties.....but we dont suffer any ill effects.
Enword
1,900
7,999
Devon
Coach Built
All domestic water supplies has to be food safe ie No leaching of harmful chemicals or toxins, else we would still using lead pipe which was outlawed years ago!
