Waster water release tool (1 Viewer)
GeebeeJaybee
293
349
St Helens
A Class - Adria Vision
newbie
We recently had a problem with out waste water in that it wouldn't shut off. It has been partially replaced to fix the problem but now needs a tool to open and close the outlet.
The fitter swears blind he left the tool in the MH when he fixed it but if he did it has spontaneously combusted!
I now deperately need to get one before Friday! There is a grey square nut maybe 10 or 12 mm square that I assume a sort of box spanner fits over to turn. Apparently a lot of german models have this sort of thing. No size of socket will fit it due to it being square.
Does anyone know where I can get one quickly as we are due to be away this weekend?
Jen
2,373
10,306
adjustable spanner would do it..
none in your tool box ?
if not, any DIY or tool store
GeebeeJaybee
GeebeeJaybee
293
349
St Helens
newbie
The thing is recessed in a hole only slightly bigger so you can't get a spanner round it. It is the square nut in the round hole on this photo (sounds like play school!).
Wickolad
490
542
Wickersley
Jen
Measure the exact size of the square nut and go buy a spanner from diy store, or as scotjimlad suggests, an adjustable spanner for the time being. Make sure you adjust to a firm fit.
Edit: just seen update picture.
Measure the size, buy a cheap spanner and bend the handle at 90 deg close to the business end of the spanner, if you get a long enough spanner, bend the other end 90 opposite way to act as a handle.
This could be done in a decent vice by use of a hammer, wear protective goggles and a bit of heat applied to area to be bent will make it easier..
If you have a socket set, try the 3/8" or 1/2" extention bar for size on the nut for size, it may give you another idea if it fits ok, you could just buy a cheap extention bar a get that bent at a 90 degree angle, may work better than a spanner
13,094
101,527
Bolsover, Derbyshire
Hymer S800
not long enough
It doesn't look square to me, are you sure you cant get a socket on it?
Failing that the adjustable end on would still get it, but you will need a small one to get in that hole (y)
GeebeeJaybee
GeebeeJaybee
293
349
St Helens
newbie
The photo isn't great as it is so far underneath! It is definitely square though.
GeebeeJaybee
GeebeeJaybee
293
349
St Helens
newbie
Measure the exact size of the square nut and go buy a spanner from diy store, or as scotjimlad suggests, an adjustable spanner for the time being. Make sure you adjust to a firm fit or you could soon round off the plastic corners of the nut.
Yeah - we have tools coming out of our ears - hubby is a mad mountain biker and has more spanners and sockets than could ever conceivable be needed.
Nowt fits this though! We could have forced a socket on but it was rounding the corners (whcih is why it maybe doesn't look sqaure).
Apr 21, 2009
546
35,068
East Cowes, PO32 6RU
Caravan
Caravan since 1970, motorhome or RV since 1999 then back to a caravan in 2017.
A 12 point socket will fit a square and hexagon nut - good tool shop will stock them.
Jun 11, 2011
376
435
Somerset
hymer s820
hya britool do square nut sockets ??
2,373
10,306
View attachment 91872 The thing is recessed in a hole only slightly bigger so you can't get a spanner round it. It is the square nut in the round hole on this photo (sounds like play school!).
hmm.. not so easy then.. needs that 'special key' ...
if you were handy you could make a key using a piece of steel conduit with two notches cut in the end
sorry can't help further
May 31, 2015
11,712
44,634
Ducato PVC
Getting Better
Buy these box spanner sat screw fix only a tenner and one will fit..(y)
Mar 16, 2010
3,058
30,900
Carmarthenshire
In between
Since 1988
Is this the type of thing? This is the one we have for our van which is German
13,094
101,527
Hymer S800
not long enough
A set of moles grips would probably do, is that what you mean by gator grips
still could be an issue with the hole size though
best of luck (y)
Wickolad
490
542
Wickersley
GeebeeJaybee
GeebeeJaybee
293
349
St Helens
newbie
best of luck (y)
No you can't get mole grips in - tried that I'm afraid.
This is a gator grip Broken Link Removed
43,357
49,636
How big is it ?
1/2" 3/8" 1/4" ?
If so you could use a regular socket backwards....the square end on the nut.
A regular socket extension bar will then fit the other end of the back to front socket (where the nut would usually fit)....one size socket or another WILL fit the extension bar
GeebeeJaybee
GeebeeJaybee
293
349
St Helens
newbie
Just had a call back from the fitter who now denies the story of a tool (that he told me himself several times) and says he cut a hole in the garage floor and the handle is there!
My answer (very restrained for me) was "you better not have cut a hole in the floor of our heated garage!!!!!!" Wil have a look when I get home tonight.
Badknee
7,408
413,657
notloB
Vantage Neo
Living the dream.
:Eeek::Eeek::Eeek:
Feb 24, 2013
13,094
101,527
Hymer S800
not long enough
Hurry home, this is getting very interesting now o_O
Lookaround
59
19
Ireland
This is the tool I have for my Possl PVC. The inside of the square measures 8mm and the first part of the tool itself is about 3 inches, then the corner and then the handle part is about 6 inches. My release valve is at the edge of the van so if I lost this tool is be able to use a wrench - even though it is a very stiff its only a quarter of a turn. I'm not sure if these measurements are of any use but hopefully you'll get sorted soon.
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
I just get the wife to crawl underneath when it's full. She does a great job, and I don't even get a splash. I do help her though, (in case you think that I'm a callous, using type of guy), I hold her handbag. (y)
