Waste Water level calibration. (1 Viewer)
Dazcaz
38
57
Cardiff
14 years of MHing. Many more Camping
We've spent a night and a day in our new van, a 2008 Bessacarr e769.
The control panel told us the waste tank was full so we emtied it. When empty, it was showing as half full.
Is there a way to calibrate the sensor so that it shows us a more realistic level?
Lenny HB
53,448
150,056
On the coast in West Sussex
Hymer B678 DL
If it is the type with 4 stainless steel probes in the water you need to clean the probes. They collect fat and muck. There should be an inspection hatch you can access them via.
R
Robert Clark
On our Bessie the access hatch for the waste water tank was under the van
D
Deleted member 29692
Whatever you do the gauge won't be completely accurate.
Use it as a rough guide, not gospel. (y)
TerryL
6,187
8,190
North East
Low Profile
You'll probably find the fresh water gauge will be just as inaccurate. As Nick says, use it as a rough guide, you'll soon get to know when you need to empty/refill.
As a guide we've learned that a 100 litre water tank lasts about the same as a 80 litre waste tank.
TerryL
6,187
8,190
North East
Low Profile
Dazcaz
Dazcaz
38
57
Cardiff
I gussed that things might not be that easy. Our old van has a small knob to adjust the calibration of the fresh tank, though that is not that accurate. The waste tank has an LED to warn of being full. It also had an overflow so we could tell when it was really full.... I'm hoping that the waste tank on the new van also has an overflow :) We don't have an access panel for the waste tank. Only one for the fresh.
Silver-Fox
9,269
29,112
Cheltenham Spa
Rapido
im a not so newbie
If you have a fresh water tank that holds say 100lts and that reads say 50% full then your waste tank will be around 50% full.
Would it not be easier doing it that way? :D
Feb 9, 2008
4,093
5,910
SW Scotland
LP Coachbuilt
Since 2008 after caravanning for 20 years
Just ignore it. If you crawl under the van you'll probably find a few small holes in the tank just below the top, when the water comes out of these, the tank is full.
Dazcaz
Dazcaz
38
57
Cardiff
^^^ That's my hope^^^ That's how we know the waste tank on our older van is full :)
sid1234
45
21
yorkshire
just looking
I'm a newbie
you could use one of these. Broken Link Removed
Bart
3,188
1,398
Northern Ireland
Boxer L4H2 van build
Since 2016
Just leave the grey valve OPEN all the time , that way you will be sure its empty..:imoutahere::imoutahere:
