Van now doing my head in (1 Viewer)
Oct 1, 2017
914
1,459
so we’ve decided to have short break this W end I’ve opened up the hatch where the Elektroblock and heat exchanger is and there’s pink fluid sat there, is this from the heat exchanger?
Left the heating on and it’s not putting any heat out or just a little, bled all the nipples and there is liquid there, do I now need to dump the whole system?
It’s gonna be -2 tonight so a bit cheesed off, all I seem to have done the last week is totting up all the jobs I need to sort out
Apr 27, 2008
319
450
South Wales
a-classs
Have you checked the header tank that's is in one of the cupboards there is a minimum and maximum mark make sure it's above the minimum
funflair
19,348
30,237
Guisborough
MORELO palace
since 2012
Is the fluid level OK and are we talking ALDE system.
Martin
Rudski01
Oct 1, 2017
914
1,459
Sorry yes Alde heating, i890 elegance, boiler working, pump working, gas on, just poor heat coming out
Rudski01
Oct 1, 2017
914
1,459
Ok after freezing my nuts off, resetting everything it seems I’m getting heat, what will the pink fluid coming out of the heat exchanger be,anti freeze ? Nothing else since I’ve wiped it up has come out , think I need to give the systems an overhaul,
Apr 27, 2008
319
450
South Wales
a-classs
Yes it's antifreeze g13 I think is the one for your system around £8.99 a litre
funflair
19,348
30,237
Guisborough
MORELO palace
since 2012
Pink could be engine side of the heat exchanger, what’re colour is your antifreeze?
Martin
Apr 27, 2008
319
450
South Wales
a-classs
In your bathroom there is a long radiator I would try and bleed this one first with the pump running flat out for 5/10mins on speed 3 if you can get to the switch in the cupboard in the garage .as that' s the highest point of the system
If you try to bleed the system on the other rads in the van you will draw in more air
Apr 27, 2008
319
450
South Wales
a-classs
The alde system is a tricky system to bleed when they service them they use a pump to force the air out while they refill with antifreeze.
If you can get some air out of the radiator in the bathroom this might see you through the weekend with some heat
Rudski01
Oct 1, 2017
914
1,459
Cheers thanks for your help, the pump was turning but no heat, seems the boiler may have locked out.
Need to check out the pink fluid, think you might be right funflair due to it being part of the heat exchanger/engine just not sure why it has dumped into the locker, heat exchanger may have sprung a leak, engine steady temp on the way here though
And no more fluid escaped
Jun 6, 2012
1,141
1,545
Leeds
Since 2012
If the level of coolant on your alde side has not reduced then I’d check the level of your engine coolant as I had the very same problem, pink fluid in my locker. Turned out to be the heat exchanger pump had a very small leak. Was a bugger to change but managed it. If you need any help give me a shout. The main issue was the position of the pump was half way inside a locker so literally had to slide half my body inside the locker and only just fit but this meant literally no arm movements to be able to work inside the locker!!
Rudski01
Oct 1, 2017
914
1,459
is this a common problem?@ dpsuk99 thanks for the offer I suspect it will be a nightmare, like you say it’s half way between two lockers,
Did you drain the full engine coolent to carry out the work?
Where did you purchase the pump from
Regards
Mark
Ps at least we had heating last night in the end:cold:
Jun 6, 2012
1,141
1,545
Leeds
Since 2012
I had noticed my engine coolant reducing ever so slightly over a 6 month period but didn’t have a clue where it was going as never a drip on the drive until I noticed a bag which has the safari room in was stained reddish and slight leak in the locker where the pump was located.
I didn’t need to drain the engine coolant as I simply used pipe clamps on the flow and return:
I then cut the pipes and replaced the pump. Here is the pump from Alde, think they wanted £280 +vat:
But I managed to find out it is a Johnson 12v magnetic driven centrifugal circulation pump. Here are a few suppliers with varying prices:
This is the pump spec I used:
The pump needs to be installed at a specific angle but the original pump was not installed correctly (I’m my view) which may have been a cause of a small leak.
Hope this helps.
funflair
19,348
30,237
Guisborough
MORELO palace
since 2012
So @dpsuk999 I guess that's the pump to run the water around your engine block to preheat in the depths of winter.
Martin
Rudski01
Oct 1, 2017
914
1,459
Thanks for that dpsuk99, like you said it doesn’t seem to happen all the time, this is the first time I’ve noticed it, and only the second time out n the van though, thanks for all that info much appreciated, just need to confirm it is the pump :smiley:
Dec 31, 2010
2,635
5,822
Sunny South Shields
Frankia Platin i7900
Since 2010
We had the same problem on ours but the leak was coming from the top of the heat exchanger we have a ball valve fitted to the top so you can turn the flow on or off and it had a small crack in the side of it were it was connected to the exchanger no sign of the leak when cold but once heated up it would start to drip.
Aug 18, 2014
23,782
133,671
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
If you have no pipe clamps use two pairs of mole grips with some thin wood/plastic between jaws to do the same.
Jun 30, 2010
7,924
27,229
Cornwall
1992 VW Auto sleeper Mono
Since 2005 this time
Reading this thread, with all the trials and tribulations of a modern M/H , I'm really glad we are mooching around in a 1993 T4 VW Autosleeper Clubman GL.
Rudski01
Oct 1, 2017
914
1,459
Yep the more tech it gets the more that can go wrong , but these things are sent to try us and our diy :swear:skills
