Using Levelling Ramps on Your Own (2 Viewers)
mikebeaches
5,394
8,601
Bristol
Rapido V68 Van Conversion
Since 2009
Is it a Euro 6?
I think it's only the Euro 6 Comformatics that do it.
That's a possibility, and I did wonder when you said yours was 2017.
Ours is a, so called, Euro 5+ (presumably just 'Euro 5' to everybody apart from the Fiat marketing department ;) ), rather than Euro 6.
Reactions: DBK
Lenny HB
53,448
150,065
On the coast in West Sussex
Hymer B678 DL
My last van was Euro 5+ that didn't do it.
1st time I came across it on this van I thought the gearbox had gone wrong it had only done 2 miles. ?
Reactions: DBK
Wellington
676
1,667
Leicestershire
Carthago Compact 138
I'm beginning to wonder if it's easier to pitch a tent than park a MH
You canā€™t level them, either!
I donā€™t understand why there isnā€™t some sort of manual built in levelling system. People do it all the time with caravans. Motorhomes must have existing jacking points, and jacks are not exactly new or expensive technology. I know itā€™s moatly couples, but itā€™s a royal pita to do in your own, especially if you donā€™t have the ā€˜feelā€™ of it from doing it many times before with guidance.
JohnH
404
993
Southport
Just looking
I did see someone with a very slender pole with a small flag on top that was placed six inches from the front bumper. Stop when the flag moves.
cornish boy
892
2,365
Body in Hampshire, heart in Cornwall
Swift Kon Tiki 669.
not so newbie anymore - since 2016
Euro 5+. so it sounds like you have hit the nail on the head with it being Euro 6 vans onwards.
Reactions: DBK
GPW
606
878
Cambridge UK
Globescout Plus
Slight to minor!
I wonder if it's easy to weld up a couple of steel pipe sections to make an adapter: to allow a standard Ā£15 lidl bottle jack (etc.) to slot safely into the jacking points.
Then one would just put a jack under the 1 or 2 lowest jacking points and securely pump them up a bit to make it all level. The rigid connection to earth would stop swaying in the wind etc. and if a jack were to fail and sink overnight it wouldn't ever matter.
One could then throw away the scissor jack so the weight added would be minimal. And put a reminder on the steering wheel..
ABZSteve
Banned
Jan 8, 2014
1,524
1,658
Aberdeen
2018, Apache 634 150 Auto
Since 2015
Just this very minute checked mine. 2018 X290 Euro 6, reversed with the door open no problem. (y)
May 13, 2016
1,787
15,803
Elddis Accordo 105
eight years in theory, a newby in practice!!!
You can indeed just stop and park. :) Reading the ground and using any available humps and bumps is an essential skill and if we can avoid using ramps we will. We can sleep either way round in our van so if we are nose up or down then we just adjust accordingly. :)
This calls for a little 'out of the box thinking'. Everyone is using ramps to get the low wheel higher. Why not dig holes under the high wheels to make them lower ..... sorted:D
Jun 30, 2011
7,241
20,128
Barnard Castle, UK
Concorde Concerto
A bit of practice and you will get used to it after the first couple of times, don't use a sledgehammer to crack a nut, does it really have to be perfectly level anyway? No.
Jan 11, 2010
2,747
9,576
Chester
Auto-trail
Well that`s our 13th year & still loving it.
I am often parking up on my own, if I need to level the motorhome with a ramp under the near side wheels I just position the ramp, leaving the driving door open I mark a spot on the ground which is the same length as the ramp, I drive towards the marked spot but never past it and presto there you are.
May 21, 2008
4,271
7,340
Oxford
WildAx Constellation
Since 2008
[QUOTE
Of course there is a "not bothering to level" school of thought but sinks and showers not draining can be an annoyance and if we are heavily nose down the sliding door on our PVC can be a struggle to open - but on the plus side it does close itself very easily. :)
Any other options Funsters can suggest for solo levellers?
[/QUOTE]
Yes - do without them. I'm in that school. I don't want to find the room for them. I have been camper vanning for 11 years without using levellers and it's done me no harm. If there is a slight slope we opt for nose up so we are sleeping at the right angle. We avoid steep slopes and mountainsides.
Lenny HB
53,448
150,065
Hymer B678 DL
It's not supposed to, quote from the manual:-
311304
Also if you start it in gear it should automatically select neutral.
I wondering when your chassis was built, you can check on the Fiat C of C.
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
I can't breathe nose down :D .
ABZSteve
Banned
Jan 8, 2014
1,524
1,658
Aberdeen
Since 2015
Don't think I will check Lenny; probably built in 2004 and sold as a 2017/2018 model :(
TR5
Apr 30, 2008
160
191
West Berkshire
I know this is an old post, but why not work out the distance you travel to the top of the ramps, then use something to put chocks in front of the rear wheels at the right distance. Simple solution.
DBK
DBK
18,029
48,100
Plympton, Devon
PVC, Murvi Morocco
I confess I didn't at first understand what you were suggesting but I've got it now - and it's clever and might well work. :)
Feb 18, 2017
4,130
8,005
Greenwich, London, UK
Hymer MLT 570
That is how I do it, I put down a twig or a bit of litter to mark how far I have to go, usually lined up with the open door.
You can easily be accurate to within an inch or two
glenn2926
3,326
13,619
Gods country
Chausson
newbie hired 3
I just either hang out of the window or open the door whilst driving up the ramps. This is for the front wheels. Back wheels can be fun.
Nov 3, 2013
3,170
9,386
Portugal
Fiat Ducato Auto Wildax
C/van since '73 .M/h.2009
.. dig a hole in your pillow! ?
Hi.
That's SO yesterday ;)..... Buy a " Bang good Hemorroid pillow ". This would kill two birds with one stone.................
Tea Bag
Minxy
32,659
66,565
E Yorks
Carthago Compactline
Hi.
Tea Bag
Well it was 2 years ago! šŸ˜„
