I don’t know your system but looking at photo, is it a bolt broke( red arrow) and the bracket should be rotated (green arrow)Thanks Jim
picture shows where the problem is. I think it must be associated with the toothed section
Yes the 2 arms should be attached to the welded bolt as you show in red.Or View attachment 456798
with so thing broken off at blue circle
I unfortunately can’t get the photo you require. The one I posted was one I found after loads and loads of internet hunting, as for some reason I became quite obsessed with finding a answer to your question.Landy Andy
Sorry I can’t get access to reply to your last post to me ????
The picture you show is the correct A frame. The part that I need to see is the underside of your photo.
Everything is connected including the Clevis pin.
on the underside you will see a serrated section which slides under the securing bolts I think I am missing a similar shaped part which slides into the toothed section. It would be great if you post a pic of the underside
John
