- Oct 29, 2016
- 4,504
- 52,732
- Carthago C Tourer
- Motor Homing 5 years, caravan previously
Hi Everyone, sorry if this aspect of setting up the Tyrepal TPMS has been mentioned before, but I just wanted an idea of what Plus & Minus figures you have set for your Tyrepal?
The reason I ask is that so many of us have different vans with different tyres, pressures and loading's.
There are as you know 2 alarm warnings one for over and under pressure, and another for overheat.
I know that all settings should be made while the van tyres are at ambient temp, but I dont want the alarm going off when the tyres get hot (within reason) on a long downhill road, that involves some light braking.
Example: If running at 79 PSI on rear axle, should I set the alarm pressure for 10 %or 15% of that? also what heat figures do you normally see running on motorways and downhill roads. I am told the tyres can get very hot, so what temp do you set yours for.
I haven't put mine on the van as yet,as I needed an accurate tyre pressure gauge first, so need any tips you can offer.
Edit: I know what it suggests on the box, but I hear some of you think differently.
Many thanks
Les
Many thanks
Les
