Tyre loosing pressure puzzle (1 Viewer)
2,345
10,186
One of the tyres on my Seicento looses pressure, about 10psi over the coarse of a few days .. it's on an alloy wheel.
I've had it checked at a tyre fitters and it hasn't got a puncture, no leak at the valve or the rim .. I've also had it in a bath of water and can't detect a leak .. all I can think of is a porous wheel, anyone heard of this and is there a solution ?
tia
Jim
Oct 15, 2007
1,622
280
Five Roads Alyth
A class RV
since 2005
If not a conventional puncture or valve issue I'd say it's still most likely the rim even if you can't see it it could be a simple as the weight of the car/deformation of the fitted tyre causes leak and no load etc it 'seals' up????
To prove simplest is flip the tyre off and inspect & clean bead mating area and try again?
Also, if you have the tyre off inspect the bead, once had a tyre place break the bead reinforcing, without realising (aledgidly) and that was interesting, seemed fine then suddenly no presure, pumped up fine but as soon as driven it would go down quickly.
11,932
9,097
Hi Jim you are probably thinking right :thumb: It happened on one of my wheels yrs ago :Sad: You can remove the trye and I was told to spray a varnish/lacquer on the inner rim, but I chose the easy option of fitting a tube :thumb::ROFLMAO:. Then again in this day will they fit a tube to a tubeless tyre ?????? It is not as though you are going for a speed record :ROFLMAO::ROFLMAO: so you may find a friendly tyre fitter who will fit one for you :thumb:
terry
11,932
9,097
Hi again Jim I just thought of the same solution as Sundowner :ROFLMAO::ROFLMAO: but he beat me to it :ROFLMAO::ROFLMAO:
terry
2,345
10,186
Thanks guys..
I think I'll try pumping some of the puncture repair goop into it and see if that works.. :winky:
old-mo
Extra Special
16,343
93,692
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
Two ways round the porous metal bit..
Both necessitate taking the tyre off ..:cry:
1.. Tape up the wheel rim (edge where tyre fit`s) and degrease the rest and get a aerosol of clear laquer and give a few coats..
2. Fit an inner tube,, probably the easiest solution.. :thumb:
old-mo
Extra Special
16,343
93,692
Weymouth. Dorset...
Woop`s,,, Sorry just seen terry`s post.. :Doh::Blush:
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
hi jim ,,go to a farm supplier n get some green oko works everytime unless you get a real big hole in your tyre.
Sundowners
3,289
3,571
Suffolk/Central Portugal
37 years
I am not sure that fitting a tube into a tubeless is the correct thing to do these days, anyway I would not feel confident with one on a motorhome (I know yours is just for a car) It would be better than nothing on the spare though.
2,345
10,186
Hi Nigel ,
tend to agree and would otherwise change it to the spare, but it's a skinny space saver metal rim .. will try the lazy option first and squirt some puncture repair goop in ..
Jim
andy rob
4
I wouldn't spray another thing in the tyre than air, these get you home fix's on a flat tyre, will inflate the tyre ,but they contaiminate the tyre.
take tyre off rim, turn it around (I guess it not a directional), spin the wheel on the tyre balancer & use some sort of abrisive device to 'ruff' up the edge of the bead (wire brush or maybe somtihng a bit more ) & put loads of the white tyre sealler on when they fit the tyre
job done :thumb:
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
it may be get you home but having used it in maroc n got home from there it seems to work. as for damaging the tyre it does make it hard to repair later but if it stays up why repair. you can still fit a tube . tubes can be fitted into tubeless tyres but not advised on very low profile tyres . then its only tyre distributers advice not law.
Sundowners
3,289
3,571
37 years
It does look as though Jim may have to buy a new wheel if he can't make one of these fixes work,:cry::cry: he is pretty sure that the leak is not in the tyre, best of luck Jim.
Nigel
ginge61
429
n/wales
c class/t25 vw
since noah was a lad lol
go to a tyre depot make sure the cleen the rim well wire brush then they have a black sealing compound they brush on the rim norm works
43,334
49,533
terry
:whatthe::Eeek: never, ever fit a tube in a tubeless tyre.....
the internal surface structure of the tubeless tyre is completely different to the old tubed tyres and the friction between tyre and tube will eventually cause a sudden blowout:Eeek:
11,932
9,097
:Eeek::Eeek::ROFLMAO::thumb: I knew there was a reason in this day and age John :ROFLMAO: just did not know why :ROFLMAO: Me if the glupy stuff did not work I would still stick a tube in and make sure it was on the back :ROFLMAO: especially on a wacky fiat that will only be used around town :thumb::ROFLMAO::ROFLMAO:
terry
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
hi pappa not all tubeless have the ines on the inside its a matter of look n see. mitchelin have a lovely smooth inside. wonder what brian in wales has to say he runs a tyre shop.you are right some have lines very thick.
2,345
10,186
terry
heh... :Angry: ... I'll have you know this is a cool mean racing machine .. :Cool:
a highly tuned piece of Italian engineering..... built in Poland :ROFLMAO::ROFLMAO:
anyways.. I bought some Holts goop and put it in today.. I'll report back on the outcome .. thanks for all the suggestions guys.. :thumb:
11,932
9,097
:ROFLMAO::thumb:Remember Jim I have a wacky fiat (ford badged )Iveco m/h :thumb::ROFLMAO::winky: Built in god knows where and on my drive in sunny S Yorks
terry
2,321
1,991
West Yorkshire...Halifax
Vanless....BUT....!!!!
A friend of mine had the same problem a couple of years ago, he had a Ford Fusion on alloy wheels, it turned out it was the actual alloy wheel itself.At the time the fault manifested itself the car was only 2 months old ,and only had around 250 miles under it's wheels, so he took it back and told the Ford dealers the problem, asked for a replacement (very loudly I may add) and they did replace it
The dealers did try the old your not driving it right routine this fella is an "IAM" driver has done the Police advanced course like meself so that didn't work with him...Result
Driver..1
Dealers 0
:thumb::thumb::thumb:
So unfortunately Jim you may end up getting a new wheel:Doh::Doh::Doh:
2,345
10,186
Sorted, now almost three weeks since injecting the Holts the pressure hasn't dropped..
:Smile:
Heyupluv
3,862
1,593
France,
touring many years..42+
leak
JIM
I had similar trouble on a alloy rim...took it back to the fitters who could not find a leak but what they did do was release the pressure and break the seal from the rim, they then painted with brush the tyre rim with "Tyre Seal" then re-inflated the tyre ...this is a black liquid that turns into a solid rubber after a few minutes.....with me everything was OK afterwards ...the fitters said it was normal for alloys to leak and also hard to find the leak...
Mel
