Toilet Fan (1 Viewer)
Jwcgas
22
12
Ton Pentre Rhondda
Just gave the toilet and enclosure a good clean, herindoors complained about a constant smell from it, this one has a fan fitted to it with a charcoal filter. Changed the charcoal for some I had from my old job ( gasman). When I checked the fan, which is fitted flush (get it) to
the floor, there wasn't any hole cut under it, so any smell would just be blown back into the enclosure. Doh! So I've cut a hole now which vents, luckily, on top of wheel arch cover away from any water ingress. Fan now sounds a lot better. Will check smells next week when we're in Pembrey. Just wondered if anyone has had this problem.
Oct 20, 2010
2,249
37,618
Burry Port South Wales
Since 2003
Looks like a botched attempt to fit a Thetford SOG kit, the hard part of the fit is cutting the vent hole and fitting the plastic vent funnel, it can even mean removing the complete lower toilet assembly to get access.
Now you have cut a hole under the fan make sure you seal the wood in the hole, if there is any chance of water getting to the underside then fit a short length of plastic tubing to line hole and seal it with mastic top and bottom.
Cheers
Ed
Jwcgas
Jwcgas
22
12
Ton Pentre Rhondda
This one is the Thetford C260 with a built in fan, not the SOG, which I fitted to my old van. I take on board your point about sealing the wood Ed, I'll apply some Unibond around the hole I cut out. Cheers.
Hellski
989
2,972
Cheltenham
N+B Arto 76 LE
Just awaiting the Thetford kit for mine, not looking forward to drilling the hole as the instructions mention a 85mm holesaw but looking at the pictures, the vent is shaped as a funnel as @Sheddy mentions(n)
Going to wait until I've got the kit and see if something can be adapted for a neater job.
Oct 20, 2010
2,249
37,618
Since 2003
What I suggested earlier is a reasonable solution, measure the size of the vent hole in the base of the filter housing about 40mm I think, center drill through the floor(s) from the empty cassette space and then drill the large hole from below. You may find there is a gap between the base of the toilet floor and the floor of the van. Seal the wood in the holes then fit and secure with sikaflex a small length of 40mm waste plastic pipe flush to the top of the hole below the fan plastic housing and protruding about 15mm underneath the van floor, seal top and bottom edges with sikaflex.
For replacement filters, use activated charcoal, empty and replace the contents of the filter box,or alternatively if you are parked next to undesirable folk take the filter out ;)
Cheers
Ed
Hellski
989
2,972
Cheltenham
N+B Arto 76 LE
Cheers
Ed
Excellent information Ed and very much appreciated(y)
53,701
151,012
It does the same job as the SOG
I order the SOG on the new van, it came with the Thetford one as well except the filter wasn't installed. I disconnected the Thetford fan.
After reading the Thetford instructions glad I paid the extra for the SOG, SOG filter is changed once a year Thetford one 4 weeks that's expensive at 20 quid a pop.
Jul 5, 2013
11,742
13,735
Had ours for one and a half years and not changed it yet.
icantremember
8,344
17,570
Near to Watton in Norfolk
Hymer T-SL668
since 2005
Ah! I wondered who it was.:wink:
I agree, a 4 week replacement is ridiculous and unnecessary .. just a sales ploy.
When we had a SOG I used to replenish the filter with activated charcoal .... will do the same with the Thetford although it is a different makeup to SOG.
Shrimp
May 27, 2015
3,998
33,672
Bedfordshire, UK
Hymer B584
Long time
Our loo fan works well and is correctly fitted-by hubby, but it started to be a bit pongy, so replaced charcoal filter and cleaned the pipe that goes between cassette and fan.
All good now!
