thetford water not flowing (1 Viewer)
ShiftZZ
21,383
84,579
Dark Side of the Moon
I have a button on top of the Thetford and it was working well, but this morning its stopped flushing water. Yes, I have water, yes I have power, cant see where the fuse is.. Any suggestions? At this rate I may have to lower myself to using a public loo or a Burstner..
Nov 4, 2011
5,941
38,967
Uk
On our Hymer there is a fuse inside the toilet box compartment, on the left hand side, but I'm not sure what it does. Maybe worth a look.
DuxDeluxe
14,658
72,784
Planet Zog
A woosh bang van
Yes, remove the cassette and have a look for the fuse. It should be there. I had a problem once when the flush tank had run dry and did not work when refilled. The pump simply needed repriming by filling up the tank very full and letting gravity do its job. However, you probably don't have a separate tank...... New van doesn't
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
Take out cassette and open slide, put hand in and at far corner you will find the fuse you are looking for. It does help if said cassette is full at the time ::bigsmile:.
