The SOG system eliminates the need for chemicals though some use bio liquid as well. The Thetford extractor system which is not a SOG operates differently, I don’t think they make the same claims about not needing toilet chemicals.
I've had both - current van has the Thetford system. There is no difference in the way they operate.The Thetford system draws the air/pong from within the cassette itself, what's the difference from a SOG?
The difference is in what they claim to do. SOG says it eliminates the need for chemicals whereas Thetford says it eliminates the chemical odours from the washroom. It may well be that the Thetford system works just as well as SOG but they just want you to buy their chemicals as well as their extractor fan.The Thetford system draws the air/pong from within the cassette itself, what's the difference from a SOG?
You can cut the wire to the fan and install a courtesy light extender to allow the fan to run on for an extra minuteI've got thru the door, do you think the fan runs long enough
The big question is how much do you use the toilet? Recommended once a season if you only use it for a few weeks per year. More often if you use it regularly. Think every 6 weeks to 2 months. If it is the black carbon foam sheet type, buy cooker hood filters and cut loads out of a single sheet. The activated carbon plastic boxes can be refilled if you open it up. Paying for branded filters is ridiculous money for what it ishow often do you change the filter
good point where do I get courtesy light extender?
what about the oven filter where do you get that.
Our first van had a door vent SOG I tried that totally useless compared to the genuine filter.it is the black carbon foam sheet type, buy cooker hood filters and cut loads out of a single sheet.
