- Feb 14, 2021
- 4,459
- 10,088
- Burstner Lyseo 727G
- 3 years 30,000 miles UK and Europe.. Campsites and off Grid.
I thought I'd start a new thread on this as it's a while since I last discussed it and a few things have been learnt but no fix.
Problem - works fine on EHU and battery (when engine is running) but not on Gas. Flame is good. Gas is actually on continuously - never switches off. This has been an issue since July. (But maybe before but not noticed as I was on EHU a lot???) Van was brand new on March.
I had a Thetford specialist look at it in Spain and he replaced a couple of bits (Burner and Selonoid valve.) But no joy.
He contacted Thetford and they suggested the Spiral in the Chimney could be an issue. Some fridges were missing them due to production failures. However I understand this is retain heat (or direct it)- and it clearly works with the electric elements. It is impossible to access the Spiral to even look out with out taking the burner section to bits and I don't want to do this not being knowledgeable. Also don't want to risk invalidating the guarantee.)
My dealer hasn't a clue. He contacted a Thetford specialist in the UK but he is on holiday for a month or so but he did say - remove fuse for 5 mins. I tried this but removing all fuses (leisure battery, cab battery and D+ fuse) but no improvement -......or maybe???
I had the Gas for for 19 hours and the freezer seems to work. I cup of water I put in there has solidly froze. However the top part of the fridge (which is usually the coldest and can go to 0 degrees on electric in the summer) is only on 6 degrees. This is with an outside temp of 10 or 11. So not much good.
Getting hold of a Thetford technician in the UK is nigh on impossible but I will pursue through dealer and directly. (Wished I lived in Spain - the bloke there would sort it I am sure but I was only in his area for a few days)
So maybe anyone who hasn't seen this before might have some ideas? Or if you read my thread back in July but have new ideas to contribute.
Thanks in advance. Need to get this sorted before next season!
