I found a really good sounding one in oban which I enquired about and he's sent me an application form by email , problem is how do I fill it in and send it back.
I may give him a phone
If he's sent it via email he's surely expecting it back via email. Have you got a laptop with you? Easy enough to do on that with a text editor but not sure about on a mobile although I'm sure there will be a way.
I had the same problem I found a tourist info emailed it to them they printed it I filled it in got them to scan it and send it to me then forwarded it on
Yeah I don't have a laptop or a printer with me.
I had both last year and never used them so ditched them when I was home :swear:
The tourist information idea is a good one though might do that
That's an idea
Is it not just a case of opening the application form then adding in your answers and emailing it back?
Handy little aire for anyone in this area , has the usual free fill and dump but also a weighbridge for €0.30
Its between Salamanca and Avila
I'm glad to find out that fully loaded with full fuel and full water and gas that I've still 160kg spare payload ?
Well we arrived in Avila around 12.30 so after a sandwich we went to have a look around the city. ...to be honest apart from the wall it's a little dull and boring:( we wanted to walk around the top of the wall but for some dumb reason dogs aren't allowed so couldn't do that.
So back at the van contemplating moving on .
Here's the pics i took
Oh dear before u r planning to be back ? Is a pity cos a lovely site
Yes they all seem to be advertising very early for a march /April start
I mean they could offer someone the job in November but anything could happen between then and March
That is true cos I am sure it would suit you down to the ground
Yeah I've found a few advertising already which I wasn't expecting. I'm obviously still in Spain so filling in applications and attending interviews I can't do till I'm back in UK. I hadn't expected them to be advertising so early as its a long time till March..
can you not interview by face time or similar?
We are parked up at the Bull ring,, will look out for you,,BUSBY?
Fwiw ours did that the other day. Then a few hours later when brewing up the gas ran out. Changed the bottle over and the truma started working again. Why, as the pressure reducer should "smooth" out any change in pressure I don't know, but there you go...
I think I've found the issue with mine ,if I disconnect the room temperature sender it will run full throttle no probs, as soon as I reconnect sensor it stops
But red light still flashes when sensor disconnected
So been and done some shopping and had a hike up and around the view points .....still not been in the actual city but you get some nice views of the castle the cathedral and the aquaduct from viewpoints around it.
Went to the official aire but a bit crowded and not very level and a good bit away from the city so I've found a spot between there and the cathedral but backing on to fields and hills.
Here's some more pics .......It is a lovely castle very kids fairy tale looking
It's only 10 min walk in to the Aquaduct and another 10 mins up a 110 steps to the Cathederal ?? from the aire at the bullring. Having a beer in Paza Mayor.? BUSBY.
I should be about 6 minutes walk then lol
