Lenny HB
- Oct 18, 2007
- 53,448
- 150,064
- Hymer B678 DL
Friends/neighbors Autosleeper PVC, I'm helping him sort out the water pump that has failed.
I have never seen such a bad installation, a submersible pump in the tank. There is no hatch in the floor to access the pump in the tank, the only access is via an inspection hatch on the bottom of the tank. With the hatch off you can just about get your hand in the feel the pump, the water outlet & cable entry to the tank are a right bodge all covered in black sealant. There is not enough play on the outlet pipe to drop the pump out through the bottom, it might just be possible. You could probably get away with easing the water and power inlet and get enough movement on the pump but it would be best to drop the tank down of course the tank is underslung without any insulation and all the bolts rusty.
Anyway I decided for him the best option is to fit a Sureflo pressure pump in a bedbox, a couple of holes through the floor to connect into the existing plumbing job done.
I find it unbelievable that a converter can install a serviceable item that are prone to failure where it can't be changed without major work. You would be stuffed if you were touring at the time if it failed.
