Starter battery issues
Peak District
Burstner lyseo
Newbie
After some help as my starter battery isn’t holding charge very well, we have a 2018 burstner lyseo which came with a solar panel that charges the leisure battery I got the dealer to had a connection to the starter battery so once the leisure was charged it would trickle charge the main battery as the alarm and tracker are connected to it, all has worked fine since till last month I’m pretty sure it’s down to the lack of use and light as it’s been stuck in storage from months, so I have been going over every week to run the engine. I was wondering as I have a battery charger at home if I took the leisure one off would the solar stop working or would it continually charge the main battery solving the issue I have no idea how it all works and can’t ask the dealers as we got it from Becks and their not trading anymore, any thoughts would be much appreciated
Starting the engine will probably take more out of the battery than you would replace in a 10 mile run
Where the battery positives go into the controller you could swap them over every week so the starter battery gets a good charge 👍
What controller is it?
thasks I’ll have look at that, not sure what controller it is will check when I go over later
30 seconds is all that's needed to put the charge back in the battery that is used upon starting a modern vehicle
everything is much more efficient then it used to be years ago
I was basing my advice on two things.
We had a 7 month old Ford Transit based motorhome and it was stored on a local farm. I took it out for a 20 mile run every 2 weeks and after doing this twice the battery was too low to start it
We have a 1 year old car with Stop/Start, which does not work unless the battery is fully charged. After starting you can always drive about 10 miles before the Stop/Start begins to function
Just my experience in practice, that may not be the same as the theory 😀
30 seconds to put the energy used back into an already fully charged battery,
Your start stop will not work on the car until it is warm and the conditions are right
You don't say how big the panel is but that's the cause in my book.
Solar is great when there's some sun but this time of year sun is neglegable most days... But the battery drain continues night and day.
