Squeak in van (1 Viewer)
May 22, 2019
309
111
Falmouth cornwall
Pilote p650
3 years
Hi everyone
Developed an annoying squeak thought it might be suspension but garage said no must be inside!??. Well off side now doin it and I have a thought?( dangerous I know). Van is french pilote and has air suspension with controls at the base of driver chair... could it be this? Where can you get them checked?
Feb 2, 2015
2,282
7,330
Shropshire, UK
A motorhome!
we are still learning
Hi Sue...Are you asking if its the controls or the Air suspension being at fault? Either way..I would have thought it was neither of them to be honest. It is a opinion only but the air suspension works a large rubber Sock which should not make a noise at all if any? Does it become more apparent when cornering or when in a straight line?
Trying to look at all the possibilities for you.
Kev
6,537
12,040
Herts.
Adria Coral lowline
My rear squeak, became at groan at sleeping policeman, so changed rear leaf spring bushes. As I removed old ones I knew it wasn’t the problem as they were in such good condition. It did and no more squeak or groan.
447
39,085
Okehampton
Swift Mondial
Since 2016
We had a squeak/ squeal from the front. Turns out it was the crankshaft pulley and the auxiliary belts. Just cost me £650 to have it all fixed/changed☹😫
Sue coulson
May 22, 2019
309
111
Falmouth cornwall
Pilote p650
3 years
Kev
Hi Kevin not cornering all the time when van is moved slightly
