I wonder if the spare wheel is included in the unladen weight I think you could argue it is not.
¬¬¬There was someone on here who had similar to you a few years before & he then queried it only to be told that nothing could be done as too long had passed &
I remember now that it was you !I complained but the legal advice I got was that once you accept the notice you have no recourse in law to have it overturned..so I was stuck with 3 points when in fact technically I was within my permitted speed for a motor home..
Andy..
If it was on the V5 then that would be usedI wonder if the unladen weight used in any prosecution / fine would be the number quoted on the V5 or the actual, measured unladen weight![]()
Our 7,5T flat bed trucks unladen weight did not include the rear mounted crane installed later.I’ve added semi air suspension and solar, to my MoHo, so would that weight now be included in the Unladen definition or could I argue they were removable accessories??
As said that isn't Unladen weight-It’s shown as “Mass in Service” on mine. Shows as 3000kg.
Finally (I promise!), if you do stick to traditional tubes and get a puncture, make a note of where the hole is in the tube and check the area of the tyre where the hole would have been.
Also, run your finger gently around the inside of the tyre to make sure whatever caused the puncture is not still stuck in the tyre! If you don’t it.l just cause more punctures.
Interesting one way of challenging the system: a few years ago I had a speeding notice, I live in Essex the speeding incident was in Birmingham and whilst I did go to Bham for business I did nt go on that day I had gone to Cambridge. So I kept getting notices and they kept getting more threatening I just kept ignoring them. Finally I was called to court, the prosecution read out my registration number which was correct, they then stated the vehicle was a blue 4 door saloon, I pointed out that my vehicle was actually a silver two door coupe. Th magistrate was brilliant the prosecution was told in no uncertain terms to get their house in order, I had an apology for my time being wasted. You could have had some fun in doing the same![]()
I rented a car for 2days for local travel to work. Returned the car with no concerns.Did you not ask the police for a description or photograph of the vehicle if you knew it wasn't you, would have saved a lot of hassle and wasted time.
If the 'system' is lazy sometimes it needs a poke, I was not rude or unpleasant, but maybe just maybe the department conserned should have bothered to double check this facts in the first instance. Had they have sent me a picture with the NIP then I could have responded but as they had not even done that as a courtesy I would do the same again. Having taken the course of action I did I hope that department is a little more diligent and it helps save others from having thier time wasted.I rented a car for 2days for local travel to work. Returned the car with no concerns.
Within two weeks I had a speeding ticket - for an offence in Southsea
The rental company had given my details to the police with no checks in their vehicle and tried to charge me an admin fee.
I didn’t do nothing, I wrote to the police with details of the rental period and mileage explaining that a) I hadn’t done enough miles in the rental car in the time I had the car to go one way to Southsea from where I’d collected the car and b) had an alibi for my real location at the time of the offence.
After a delay I got an apology letter from the relevant police force.
That was nicer than ignoring the charge to later mess about in court, IMO
No requirement to show it on the V5.I can’t see an unladen weight on my V5.
No its not included.I wonder if the spare wheel is included in the unladen weight I think you could argue it is not.
In my scenario my beef was with the rental company blindly passing on my details with out checks and trying to charge me.If the 'system' is lazy sometimes it needs a poke, I was not rude or unpleasant, but maybe just maybe the department conserned should have bothered to double check this facts in the first instance. Had they have sent me a picture with the NIP then I could have responded but as they had not even done that as a courtesy I would do the same again. Having taken the course of action I did I hope that department is a little more diligent and it helps save others from having thier time wasted.
Good to hear you had an apology
Seems the whole system needs sorting. The speed limits depends upon the maximum laden weight, and/or whether or not a 'Van with Windows' is still a commercial van or a van converted to a motor caravan and this information is not on the V5Just to throw another spanner in the works, vehicles are classed as M1 passenger carrying or N1 goods vehicle with different speed limits on the V5. A lot of vehicles are down correctly as "Motor Caravan" on the V5 but can be either M1 or N1 also so which part does the roadside camera system use to check vehicle speed limits?
Lenny HB does the DVLA have a copy or access to the CoC? Will they obtain it when the van is registered? (And if they have the CoC they’re missing a trick here by being able to supply a replacement to owners who haven’t got one and charge them say £80)No requirement to show it on the V5.
It may be on your C of C also Carthago show it on the price list about the only manufacture that gives unladen weight.
As in previous posts if they haven’t how will the various agency’s know whether to issue the correct speeding ticket.
