Do you think I’m ok using a 12v splitter plug so that I can power my avtex tv and a sound bar ?
Are the sound bars worth their money ?Me Also!
TRUE?Big improvement on the sound but unless you have arc hdmi output on the tv you have to turn the volume up on a different controller.
So i now have 2 remotes one for volume and one to change channel ? time for me to upgrade to the avtex pro ?
Definitely, the base is non existent on tv, sound bar much better, very noticeable when you toggle between the two,Nope disagree... yes louder but that is not the function of a sound bar... it is the quality... you don't go to state of the art cinema for volume you go for surround sound.. and clarity.
No, which is stupidSlight hi jack but interested to know if the soundbar is in sync with the telly when connected via Bluetooth?
Another "No" from me. Mind you there's no need when the two are normally inches apart. The two remotes issue doesn't exist with my cheapo (£25) soundbar. Plugged into the TV headphone socket the TV volume control works fine. There's a sweet spot for the soundbar setting but once noted the volume can be varied using the TV remote.No, which is stupid
Why is it stupid? Some Bluetooth /wireless devices can suffer latency with video to sound.No, which is stupid
If, Avtex has manufactured the sound bar to overcome the sound quality of their TV's you would think as a manufacturer that their "bespoke" sound bar would work with their own TV'sWhy is it stupid? Some Bluetooth /wireless devices can suffer latency with video to sound.
I've done that in the past. I don't do visible wiring so that alone was a major headache. The sound via the radio in this case would also be behind me which meant crossing L/R in the cable. My cheap soundbar involves 9" of plugged wiring and is above the TV on the same mount. So when the TV is retrieved from its cave the soundbar comes with it and is ready for use.Why not just wire the TV sound to your head unit, that's what I always do.
Definitely - got the Avtex sound bar for Christmas - it is excellent.Are the sound bars worth their money ?
