Solar panel size recommendations sought. (1 Viewer)
Trikeman
1,649
3,095
Wilds of Ceredigion.
AT 634 Apache.
Since 2011.
Hi All,
made the decision and we are going for it with a solar panel(s). We have a pair of 110ah leisure batteries and generally use led interior lights, pumps and occasional TV. I have a belief that the bigger the better as far as power generation is concerned, also length/width is not too much of an issue as the roof is not too cluttered.
Anyone with a similar set-up/usage and what wattage do you use/recommend? I would like to have the panel(s) charging, predominantly the leisure batteries, however with the ability to charge the main and possibly the toad if ever needed.
Suppliers and possibly fitting companies recommendations also appreciated.
Regards,
Trikeman. :winky:
simbadog
1,683
3,337
Wengen
A/S Broadway EL 2021
We have a 100W panel & have done a week parked up with no ehu, using TV & LED lights etc. Seems fine :Smile:
Xabia
1,186
821
Since 1996
I fitted a 120 watt panel to charge my battery bank with the same amperage as yours, works well so far.
As far as suppliers are concerned you won't get better advice or products than from http://www.aandncaravanservices.co.uk. Speak to Alan and he will give you all the advice you need.
Fitted mine myself, it was quite easy.
Mike
Nov 14, 2009
425
252
normandy
c class
16 years
hi trikeman, i have 2 x 125 a/hour batts and 210 watts of panels on the roof. one 130 watt and one 80 watt panel. the 130 watt tilts up to get the best from the low sun in winter. my advice is make sure the cable sizes are correct for the distance they have to travel to regulator and then the batteries. positioning the panels is very important, do not put them near anything that can cast a shadow (heki , sat dish ect) on any part of a panel as if you do you will be lucky to get any useable power from them at all.
Trikeman
Trikeman
1,649
3,095
AT 634 Apache.
Since 2011.
Mike
Hi Xabia, thanks for the post and recommendation, unfortunately they no longer supply or fit solar panels any longer according to their website.
Thanks though for recommendation.
Regards,
Trikeman. :winky:
Oct 20, 2010
2,248
37,617
Burry Port South Wales
Since 2003
Solar Panel Size
Hi,
Had a 120w panel fitted earlier this year with two 110ah batteries by the nice folks at Vanplus in South Wales.
The longest we have been off the juice was 10 nights in the French Alps for Le Tour.
The gas fridge didn't work because of the slope, so we were running a large 30L 12v cooler, also a mains inverter for the Sky Box, and all the normal stuff as well.
The system was more than adequate.
Cheers
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
Hi All,
Regards,
Trikeman. :winky:
I have similar usage to you and a single 180Ah leisure battery. With 2x100W semi flexibles, the batteries have always been fully charged by 10am and, in the height of summer, by 8am.
At the beginning of December, I got a call from the storage farm. The owner had been walking around and noticed I'd left the interior lights on (10W of LEDs). They had actually been on for a month. I went in the next morning just as the sun would have been rising had it not been raining for a week. Still 12.2V on the battery.
Xabia
1,186
821
Since 1996
Regards,
Trikeman. :winky:
Sorry about that, didn't realise that they had stopped selling the panels. Shame because they were first class when I dealt with them a few months ago.
Mike
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
Well we have 2 x 105ah batteries and a paltry 30 watt solar panel on the roof. All lights are led, but we managed the best part of a week in one spot and the batteries were pretty well full when we left.
We may be getting a bigger panel fitted next year, but roof space is limited with all the roof vents and stuff on top, hopefully, technology will have improved a bit more and a 100w panel may be only a bit bigger than the one we have.
At home we have 12 x 200w solar panels on the roof, they are almost half the size of our neighbours 195w panels. Mind you, they were twice the cost!....
Allan
MikeandCarolyn
2,170
1,468
Worle,North Somerset
Hi Trikeman-we have 2 x 80w cos that's all I could fit on roof.
Don't know a supplier etc near you-but will need to find out who can do work for me when we move to Clevedon in New yr,where abouts are you ?
Mike
11,844
14,080
I have 4x100w panels, but except in the darker months this is really more than I need. In the summer we do use electric kettle, toaster, hairdryer etc through an inverter, and even then the batteries 2x125Ah + the vehicle battery are always pretty fully charged.:Smile:
Trikeman
Trikeman
1,649
3,095
AT 634 Apache.
Since 2011.
Mike
Hi Mike,
small world - we moved from Pencoed to WSM, next junction on M/Way from Clevedon. We are about 10 mins from you and we have a lot of friends in Clevedon, its a nice place too.
:thumb:
Regards,
Trikeman. :winky:
Clive
1,296
1,782
Canvey Island
Hi All,
Regards,
Trikeman. :winky:
I have very much the same set up and use 100w. Good wiring and a good regulator are very important to maximise the charge. In the summer I don't even think about power, it's just always there. The only time I get low is over New Year when all my sons friends seem to use my van as the TV lounge.
Clive :Eeek:
Jun 17, 2012
2,934
9,946
North Essex
Autotrail Delaware
>12 but <13
I use 165w set up which I installed myself.
http://www.bimblesolar.com/offgrid/12v USE THE MPPT controller, dearer but better
Stuck to roof sitting on 4 corner mounts.
Kept battery topped up for 2 weeks with inverter powering 240v TV and Freesat box. As well as laptops, phones, ipads etc for others.
It is currently sitting there passing a 1 amp trickle to the vehicle battery (see pic) as leisure battery is full. Nothing wasted and no maintenance.
The little box is from Van Bitz and is called a battery master
Trikeman
Trikeman
1,649
3,095
AT 634 Apache.
Since 2011.
Hi Larby,
thanks for your post and recommendation - cracking stuff.
I am considering fitting myself too, more for getting 'into' the self confined power side of things and understanding of the systems. I would be interested in hearing how you went about it, when you get time of course.
I spoke to a guy in the SW show who was quite knowledgeable (he should have been too - he owned the company and travelled around fitting solar kit). He was quoting around £500 all in fitted at my driveway for a 120w system with a guarantee etc - unfortunately lost all his details. My research so far has revealed there are varying qualities (outputs too) and as usual over research has started to confuse me as to which I want - hence this thread.
My van had a panel fitted before I had it (I think) as there is a large frame on the roof, but the ones I saw at the show were bond on frames which were nice and low to keep the panel snug to the body.
I am still toying whether to have it all fitted or do it myself though.
Regards,
Trikeman. :winky:
Feb 9, 2008
8,953
18,710
Corby, Northants
Coach Built
I too have 2x110 AH leisure batteries and saved a small fortune by fitting a solar panel (120 W) myself.
My Autotrail already had the solar panel controller fitted as standard and yours may be the same depending on build year.
I spoke directly with Autotrail who advised where to place solar panel and Sargent provided me with snap connecting leads to join between panel and controller.
The complete job from start to finish took less than an hour and was straight forward.
I was quoted £700.00 to have an 80 W solar panel fitted by a dealer. I paid under £250.00 to install my own 120 W solar panel.
Trikeman
Trikeman
1,649
3,095
AT 634 Apache.
Since 2011.
Hi Phil,
many, many thanks for your recommendation, never thought about the already fitted Sargent unit
:Doh:
there's a potential that the unit may well be already fitted then - Wow.
I will contact both AT and Sargent for advice on this, and if it does in fact connect in to the Sargent unit additional charge wiring may not necessarily be needed, what an idea??????? Excellent, THANKS.
:thumb:
Regards,
Trikeman. :winky:
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
Regards,
Trikeman. :winky:
The fitter could well have been CLS who are members here, panels are raised off the roof to prevent heat buildup.
cliffanger
4,846
34,035
Saltford
Hymer A class
We are also thinking of solar panels, so have read this thread with interest. We have seen the Bosch panels advertised, and they look good to us - has anyone got any thoughts on them
They are on Ebay: 200W (100W+100W) solar charging kit with advanced LCD controller 12V/24V system.
I apologise for butting in on Trikeman's thread, but wasn't sure if I should start a new thread when there is already one on the go.
Geraldine
Trikeman
Trikeman
1,649
3,095
AT 634 Apache.
Since 2011.
Geraldine
Hi Geraldine,
no apologies needed, your question is exactly the type of question that we have and the more advice/recommendations sought, the more information comes to the surface. On the Bosch panels, many of the suppliers I have spoken to (whether they sell them or not) do sing the praises of the Bosch panels/systems so should be a safe bet.
Hope you get what you need from this thread - the more the merrier :thumb:
Regards,
Trikeman. :winky:
Trikeman
Trikeman
1,649
3,095
AT 634 Apache.
Since 2011.
Bummers :cry:
Spoke to Sargent yesterday and Phillippft's suggestion of having the solar kit fed through the already fitted Sargent kit is not possible on the van I have and they recommend a 'stand alone' solar system with its own reg etc to be fitted.
A cracking suggestion though and applicable to later vans of the marque I have.
Regards,
Trikeman. :winky:
Dec 10, 2013
3,423
12,259
South Staffs
Pilote P740GJ
Hi,
I had a 140 watt panel fitted by Detroit solar panels, they do a lot of the shows.
Ran 12v tele, led lights and water pump in October no probs.
Motorhome now in storage outside and when i go to check it both batteries show a full charge.
Regards, Dave. :thumb:
Peter_n_Margaret
86
62
Adelaide, Australia
"C" class 4WD DIY
About 20 years
You can't have too much solar.
Our MH in Australia is mostly electric. We have 600W of panels and use very little gas.
2 pieces of advise.
1. Get a decent book on the subject. "Solar that Really Works" is an excellent reference. After reading this you will be able to do your own installation and be confident that it will work properly. There are many traps for the unwary.
http://www.caravanandmotorhomebooks.com/
2. Install a top quality MPPT controller that is substantially larger than you think you need in the first instance. It will then allow an increase in the capacity of the system without the need to replace the controller.
Solar is cheaper now than it ever was.
Cheers,
Peter
Trikeman
Trikeman
1,649
3,095
AT 634 Apache.
Since 2011.
Thanks Peter, good recommendation on the book.
:thumb:
I am trying to learn as much as I can on the subject, I prefer to understand what's going on and not so much have it fitted and 'it all happens by magic'. :Smile:
Your recommendation, plus another book I have on order, should get me to at least a basic understanding.
Again, thanks.
Regards,
Trikeman. :winky:
cliffanger
4,846
34,035
Saltford
Hymer A class
Very interested in the books. What is the other one you have ordered Trikeman?
Jan 28, 2008
10,121
18,388
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
while mppt controllers get more from your panels ive seen up to 15 percent they are more exspensive than the standard controllers if you have the roof space youll get more power per pound by having an extra panel
just my opinion
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
just my opinion
Exactly what i decided. I've got 200w and room for 300w more. A mppt controller would have cost another 100w panel, which would have given me 50% more power, not 15%.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
More WEIGHT too :roflmto:
My 300 watt units should produce 16 amps max at 300 watt
The mppt is producing over 18 amps from 250
Techno
Jul 28, 2010
15,475
20,756
May 2010
Many so called normal/standard regulators are so over priced by UK dealers that you might as well pay £83 for the real deal direct from Taiwan
I've been using their mppt regulators from their first mk1 incarnation right up to the latest version :thumb:
