Solar charging batteries. (5 Viewers)
Apr 8, 2015
321
292
Lincoln
15 years
I unfortunately have to run a C-pap machine during the night and when off mains I use a separate 12 car battery to power it, so as not to deplete the batteries in the motorhome. At Misterton I purchased a TOPRAY SOLAR 12 watt charger which has a cable and two crocodile clips. The question is can I connect this directly to the battery terminals. This is a stand alone battery totally divorced from the Motorhome electrics. Help/advice appreciated as we are off hook up this long weekend .
Cheers Fred
53,448
150,066
Yes, 12 watt will be OK anything bigger would need a regulator but don't expect to get much of a charge out of a 12 watt panel. on a very clear bright day you will get an amp for a couple of hours around midday, either side of that output will fall off rapidly. If you are relying on that battery you really need a minimum of 40 watts and then only OK for the summer months.
Apr 11, 2015
5,415
55,215
hull
Laika Ecovip 300
John uses Cpap too, 2 leisure batteries and solar, can manage 5 nights in fair weather, don't watch a lot of TV though. usually find that power used overnight has been recharged by midafternoon. We do carry a generator 'just in case' only used a couple of times, and that was before getting a second leisure battery.
Last van solar was sufficient even in th snow.
Feb 9, 2008
8,951
18,708
Corby, Northants
Coach Built
I have a 125W good quality German Solar Panel and the best I can get in the UK is about 5A and this is on a very bright day and for short periods. That's 10 times bigger than your 12W solar panel and I think you will struggle to get 1 Amp.
These are very good S.P. and can be connected directly to your leisure batteries, or stand alone battery.
http://www.photonicuniverse.com/en/catalog/list/category/folding-solar-kits
Humsafer
Apr 8, 2015
321
292
Lincoln
15 years
Thanks everyone, I guess the answer to the question is yes I can connect (which I will) but it will only help if I am lucky with the weather
I do have 2x 100watt Batteries and for emergency use only a 1kilowatt Honda which I hate cos they can be so antisocial.
Anyone want to buy a 12watt solar panel
Cheers Fred
Feb 9, 2008
8,951
18,708
Corby, Northants
Coach Built
I thought it worth mentioning, (as you may not be fully conversant with Solar Panels (S.P.)). The S.P. I have refereed to in my last post comes with it's own controller so you can connect it directly to your battery/ies and it immediately starts to work and requires no further attention/add on's or modification.
If you are going to purchase from elsewhere make sure it's an all embracing version and can be safelt attached to your batteries without requiring additional add on's etc.
Nov 14, 2009
425
252
normandy
c class
16 years
hi phil, thats a very low output from a 125w panel . thats more like the output of a 80w panel. you should be seeing 8 amps ish in direct sunlight. have you got any shadows on the panel from anything on your roof? any shadow whatsoever will dramatically reduce the output.
53,448
150,066
Agree on a good day get over 5 amps out of each of our 100 watt panels, maybe not a very good regulator.
Feb 9, 2008
8,951
18,708
Corby, Northants
Coach Built
Seanoo, I cant understand how you arrive at that figure.
The specification for my S.P. is as follows.
Solar panel 125W: Compact & Powerful Mono crystalline solar panels are made of Q-cell solar cells
-->Power: 125W
-->Dimensions: 1135 x 660 x 35 (mm)
-->Voltage: 17.2V
-->Open-Circuit voltage: 21.6V
-->Max Current: 7.26A
-->Short circuit current: 8.13A
-->Max voltage: 1000V
-->Weight: 8.8kg
-->Efficiency: >18%
-->no of cells: 36
As you can see the maximum current is only 7.62 Amp and this is a high quality S.P. Also, no S.P. is going to achieve anything like the maximum output and considerably less in the UK, even in good sunlight. The most I have ever obtained is 5.6 Amp and this is when in Morocco. I do not know where you are getting your facts from but ||I would advise you re- check as they make no sense.
As for an 80 W S.P. maximum current around 4.5 Amp so expect to get about 3 Amps in the UK at best.
43,331
49,468
As a rule of thumb, any panel less than 20watts doesn't need a controller......unless you have a very small battery.
20w (around 1A to 1.5A charge output) cannot overcharge your battery
18,029
48,100
-->Power: 125W
-->Voltage: 17.2V
-->Weight: 8.8kg
-->Efficiency: >18%
-->no of cells: 36
The 7.26 current figure is from the panel and at a voltage of around 17 volts. The controller will reduce the voltage and increase the current, assuming it isn't a basic shunt type controller. Ignoring losses in the controller a 125W panel should be capable of producing 10 amps at 12.5 volts for example.
Nov 14, 2009
425
252
normandy
c class
16 years
i u
-->Power: 125W
-->Voltage: 17.2V
-->Weight: 8.8kg
-->Efficiency: >18%
-->no of cells: 36
i use a mppt charge controller with my current setup and have 210 watts on the roof , i can pull in 14 amps on a clear day in the uk no problem if my batteries are down. so thats 7 amps per 105 watt ..
before i had just an 80 watt panel and a pwm regulator and i still got close to 5 amps in the uk on a clear day in summer.
in summer the midday sun in morocco and in uk are virtually no different for a small solar installation apart from the pollution in the uk of course (and clouds lol)
looking at your link to your solar panel it shows the regulator on the back of the panel which means that it has already dropped the voltage and then this reduced charge has to travel along the 5 meters of cable to your battery via crocodile clips . it would be more efficient if you put the reg next to the battery and had short cables to the battery
53,448
150,066
Not quite, you won't get any charge at 12.5 most regulators need around 16 volts to produce a chargeable output so 125 watts should produce around 7.8 amps. I said most regulators as MPPT ones and some clever ones like the Schaudt LR1218 can boost the voltage coming in to still give a charge when sunlight levels are low but that can not increase the total power available.
18,029
48,100
I was describing the battery end of things and how the controller can increase the current by dropping the voltage from the panel. Essentially, power into the controller will equal the power going to the battery less the losses which are low. V x A in the panel cables equals V x A at the battery. It can't be otherwise, ignoring the losses in the system.
Feb 9, 2008
8,951
18,708
Corby, Northants
Coach Built
i u
The specification I posted refers to the S.P. on my roof, not the one in the link. I am impressed to say the least, that you can obtain 14 Amps from 210 W.
Feb 9, 2008
8,951
18,708
Corby, Northants
Coach Built
I was not aware of this and this is not the case with my system. I will explore in more detail.
Feb 9, 2008
8,951
18,708
Corby, Northants
Coach Built
Sorted ! Your are spot on! If my batteries were low or flat I would have seen a much bigger Amp reading from my control panel.
18,029
48,100
It's easy enough to work out what current you might get by just thinking of the wattage. V * A = W, so your 17.2 * 7.26 = 125W (more or less) If the panel was actually producing this full amount then this power can't get lost as it makes its way to the battery, apart from a few percent lost in the wires and the controller. Lets assume 5W is lost as heat somewhere so at the battery terminals there is a potential 120W to charge the battery. The same V * A = 120 applies so if the voltage was say 13v then the current would be 120/13 = 9.2 A Of course if the battery is fully charged then the controller will more or less stop charging and the current might reduce to say 0.1 amp at which point your panel will also stop putting out all but minimal current too. The only complication of course is if there is a load on somewhere this could divert power from the charging.
This current increase at the batteries does not of course apply to very simple controllers which simply connect the panel output directly to the battery which is why MPPT controllers are generally considered the best as they will maintain the panel voltage at the optimum to generate the most watts - or maximum power as the name implies. :)
Feb 9, 2008
8,951
18,708
Corby, Northants
Coach Built
This is the regulator that came factory fitted with my Motorhome. My interpretation, after reading your comments is that this regulator would allow up to 10A from my S.P. to be directed to either the Hab or Cab batteries if called for by the batteries. (I never allow my batteries to discharge much which is probably why I have been seen more than 5.5 A from my S.P. on the control panel.
https://sargentltd.co.uk/shop/product/10amp_solar_regulator/122
Nov 14, 2009
425
252
normandy
c class
16 years
hi phil , the reg you have is for the leisure batteries only from your solar panel. it wont charge the vehicle battery as well unless you have a separate battery master or similar. normally a duo controller has a separate output to charge your cab battery like this
http://www.ebay.co.uk/itm/Morningst...430530?hash=item1a100ce642:g:AYoAAOSwh-1W1smB
Feb 9, 2008
8,951
18,708
Corby, Northants
Coach Built
No That's wrong Seanoo. My control panel clearly shows which set of batteries are being charged, by how much and from what source, i.e. 3 stage charger via hook up or S.P. Or, my control panel is giving me a false reading. However, to change which set of batteries receives power from the S.P. I have to hit my kill switch then reconnect. With the 3 stage charger it's automatic.
There must be another connection somewhere otherwise how would my control panel give me all the information about my S.P. performance and perhaps a device to redirect current to the appropriate battery set.
8,951
18,708
Corby, Northants
Coach Built
Just thought I would add the above has never presented me with a problem and I can monitor both sets of battery states and If I did need to put in additional power to the cab battery when off grid I could attach my 120 W folding S.P. that is all singing and dancing.
Nov 14, 2009
425
252
normandy
c class
16 years
lol , thats what i said!! " unless you have a battery master or similar" ..... in your case you have a manual switch to swap which batteries get the charge from your solar panel.
