solar advice please (2 Viewers)
Sep 11, 2016
229
170
nottinghamshire
newbie
thanks in advance, just bought a SH MH and paid to have a solar panel fitted, upon service before I get it they have told me that they have discovered its got a 100w panel and a controller that says mppt15 on it, they have checked it and its working fine and set up to charge both van and leasure batteries. They have said they can rip it out and put new in, or give me what I was going to pay for new back.
So do you think I am right hanging onto my cash what have I got to loose. going to dealer tomorrow to give them an answer and check it out myself.
forgot to mention its a 2014 van so it shouldn't be that old
Bobby22
1,537
6,408
Rapido 680ff
since 2013
Keep you money, if it stops working you can use the cables to wire in a new one.
They are usually good for years and you will be able to check the power you are getting from it.
19,376
30,366
Or put another one on as well, check what input wattage the controller can handle and you might get away with just the panel and some wires.
Sep 3, 2012
7,557
26,084
Cheshire
C Class Elddis 175
8+ years
keep the cash and see how you get on with the 1 panel first-it may be ok. If not you can add a another panel later at one of the fix it meets(y)
Jul 5, 2013
11,731
13,711
The answer depends upon how you are going to use the van. 100W is fine if you are planning to go without EHU occasionally in the summer. If, on the other hand, you want to go without EHU for longer periods in the autumn winter and spring in the UK then at least 200W will be needed, depending, of course upon how much TV you watch, how many lights you have on and how warm you want the motorhome (the fan/pump on your heating system uses quite a bit of electricity).
You can always ask them to fit the other panel you have paid for. You could then either get another controller to run that one (I doubt the existing controller would take both) or get them to replace the existing controller with a better one that will take both panels.
Feb 16, 2013
19,739
52,053
uttoxeter
ambulance conversion
50 years
Sounds like a decent dealer, wonder they didn't just take your money and leave the one that's there, on the other hand they couldn't have checked much if they didnt know it already had one!
L
Sep 11, 2016
229
170
nottinghamshire
newbie
Your right there
