Smelling gas (1 Viewer)
Candapack
711
2,639
Fife, Scotland
Since 2013
Gas locker always has a gas smell whenever I open it. It's been in twice for checking, dealer assures me there is no leak. (PS, it's a Gaslow refillable bottle). Also, I have done my own soapy bubble test, nothing. No hissing sound of gas escaping.
Next, I marked the gauge on the bottle and left it for 24 hours. No change.
So why am I smelling gas?
Candapack
Candapack
711
2,639
Fife, Scotland
Since 2013
Ah-Ha, thank you, I do have rubber pipes.
So does gas just somehow permeate through rubber? Which would surely mean that some (maybe an infitesimal amount) is still escaping?
Lenny HB
53,430
149,981
On the coast in West Sussex
Hymer B678 DL
There is always a slight fast smell but it's a bit different to a gas leak smell. If your gas locker is enclosed with just a drop vent (ours is in the garage) they smell a lot more than the side lockers with a big open area around the bottles.
I always carry a gas sniffer.
Oct 29, 2016
4,504
52,742
Surrey
Carthago C Tourer
You could go online and get yourself a can of Gas Leak Detector spray, its what all the gas engineers use to check their gas joints are tight enough on new installs.
Screwfix do one, but Hamilton Gas products do them also.
Hope that helps.
Les
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
We have refillable bottles (Gas it) with rubber tails. Our gas locker ( sealed with just a drop vent) always smells a bit gassy. I’ve checked all connections with proper gas leak fluid, no leaks at all. It appears to be just the smell of the rubber pipe
Jan 28, 2008
10,116
18,382
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
I'm a gas engineer by trade and mine smells I've checked checked and double checked i
And there's no measurable leak the smell that they add to the gas seems to stick to anything for ever I wouldn't worry about it a true leak will soon be apparent as the smell goes every where
icantremember
8,333
17,545
Near to Watton in Norfolk
Hymer T-SL668
since 2005
I really can't explain why the smell occurs, it obviously permeates the rubber but I don't think the gas is escaping. So long as you are certain the tails are still in-date and have checked all the system for leaks there will be no danger or cost incurred through wastage.
PeteH
6,853
9,030
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
It`s NOT the gas, It`s the "Stench", This is injected into Propane at the "factory" because "pure" Propane etc; has no odour. It "clings" to everything. When I used to Examine The Tanks for Calor, The big Industrial ones. I kept a full set of clothing JUST for that job. SWMBO would not let me out of the Garage until I changed, down to the Underwear!. They all then went on the washing line for days, even then they still smelled!. Even several washes will leave a trace!. I just keep an old Spray Bottle filled with soapy Water in the gas locker and test every-time I change a bottle and periodically go round all the exposed connectors.
P.s. There are some gasses Ie; Hydrogen Sulphide, where you are only in trouble when you can no longer smell them, at which point your sense has been destroyed, and you have around 3 to 5 mins left to live!. It is also one constituent of "Natural" Methane!, fortunately only in very small quantities, and Smells of Rotten Eggs. Useless information but one reason why your "Fart" stinks!.
