smartflow water pump (2 Viewers)
lugnutt
1,190
466
wednesbury.westmidlands
autotrail apache
10 years
hi all i am looking for a water pump for my apache 700se,the one thats in it is a ...smartflow model no upo814 but it seems to be going obselete ican find a ufo814 will this be ok or can i fit a more powerfull sureflow? going from 2.2 to 2.6 flow rate?
dave
17,635
43,358
a 30psi pump will give a faster flow rate but may show up any weak joints or components. basically though you will go through a tank of water quicker. because the pump has an integral pressure switch, it just needs adjusting down a bit
lugnutt
lugnutt
1,190
466
autotrail apache
10 years
how does one do that?
43,332
49,505
there is an adjuster screw on the end of the pump...pressure switch end.
it alters the point the pump switches off....it DOES NOT alter the pressure
the pressure is defined by the pumps mechanical characteristics and is none adjustable.
the screw is there to finely adjust the auto switch-off point so the pump doesnt keep running intermittently when the tap is closed.
again, it DOES NOT alter the pressure, when the pump is running it produces 30psi (or whatever psi the pump is rated at)
