Slamming PVC door
davidroxburgh
West Sussex
Van Conversion
Since 2012
Reading some other threads I spotted an idea for a strap to close a PVC door close to the handle (LHD in our case) but I cannot see how to attach one at the other end of the door which, if you want to close quietly would be needed to close the door and ensure electrical connection.
From outside I can close quietly and push the door closed at the end nearest the back of the van so the locks function. It is the closing from the inside that puzzles me. The Westfalia has a door liner too.
Any ideas please?
I always give ours a good slam to make sure that it’s closed properly especially if we are staying at Jasmin Camping.
You could use the cab doors to go out and close it quietly If you feel the need.
You can buy a motor kit so the door closes at the touch of a button. Or use a fabric strap help on the door using one of the pre-existing screws holding the door card
Any ideas please?
I have a strap fitted approx. 2/3rds along from front edge of door, makes closing very easy and quieter.
Its to drown out the sounds of televisions blasting from the plastic monstrosities parked next door.
:reel:
The front tv in our van is mounted on what is the side wall of the fridge/freezer, so can be clearly heard outside through the fridge vents even when quiet indoors
Do you have a link for this motor kit please?
Stedall is one manufacturer and Modifero another
Thanks, alas no good for me, kitchen/worktop in way on Turkish one and no ducato on the other
Just give it a good shove!
Cant beat a swish bang lol
As an additional aid for others to identify you have a sliding door is to file a flat on one side of the door track wheels. Alternately wait until they seize up for a while, then oil them. The rhythmic rotation adds a certain panache to an otherwise dull activity.
I thought if you have a sliding door you have a legal obligation to slam it shut?
having spent part of my working life fixing work vans, I can tell you that slamming the side door as hard as you can sometimes has consequences. Like the internal mechanism getting jammed, leading to climbing in the back and taking the inside of the door apart. Not an easy task if the furniture overlaps part of the door
One thing you can do is clean the wheel and track, and lightly spray with good quality silicone spray. It needs redoing every now and then, it dries in heat and washes out in rain.
Kee-eep slamming!!
I don't have to slam the sliding door of my Boxer but I do need to use a little force. If I want to be quiet because there are people I might disturb I go through the sliding door hatch I built into my bulkhead wall (built with draw runners) and out via the drivers door. Much quieter but does involve climbing over my bench seat.
Having had a VW Westfalia for 40+ years, I found that just cracking the slide window open slightly to release the inside air pressure helps and now I have a Ducato PCV, I have fitted a handle near the back of the sliding door, just above the window (see picture). Not the most aesthetic work I have ever done but it does the job!
