I recently purchased (September last year) an Autotrail Cheyenne 696G manufactured in 2005 and fitted with a Shurflo water pump. The pump is fitted to the side wall of a compartment at the rear of the MH underneath the wardrobe, also fitted in the same compartment is the water heater and as the fire is fitted to the front of the compartment the main rear parts of the fire are also in the compartment.
During a trip away at the back end of last year when the weather was particularly cold the pump stopped working due to the thermal breaker activating (due to heat from the water heater and fire not due to the pump overworking) when I felt at the pump it was extremely warm due to the heat from the water heater and the heat from the rear of the fire which was set to 2kw due to the weather.
I wondered if anyone else has experienced this problem and if so has anyone come up with a ‘fix’ or is it something I have to live with when using the MH in the winter.
Thanks in advance for any help offered.
Bertie II
Bertie II
