Shaudt Electroblock EBL99 (Faulty)+ LR1218 + Victron Multiplus 2000 + B2B (2 Viewers)
Jul 18, 2009
11,189
17,846
HYMER B644
So, it seems my EBL99 is no longer charging from the mains (Still charges from Alernator).
I was already looking at some kind of B2B Charger when I found this issue.
I called http://www.apuljackengineering.co.uk/repair_pages/repair_page_ebl_99.html , seems quite expensive to repair or replace with a re-conditioned unit.. I have also emailed http://www.aandncaravanservices.co.uk/schaudt-elektroblock.php for their prices.
Then I got to thinking !
The Victron Inverter I have is
I could use this to charge the Hab batteries on site?
But My solar would then not charge the chassis battery, unless I made big changes to the system?
Any Suggestions welcome?
(PS: If AandA can repair for a reasonable cost, could I still use the Victron to charge as well, or do I have to disconnect the Electroblock?)
(PPS: If I fit a B2B, do I have to disconnect the electroblock?)
ET
EuroTrotters
Jul 18, 2009
11,189
17,846
HYMER B644
Yes use the charger in the Victron, disconnect mains from EBL and remove 20amp charging fuse.
The solar will only be a case of swapping a couple of wires.
Yes, it’s the swapping of the solar wires that bother me. Might need a new regulator to charge Hab and starter
Jan 4, 2020
414
567
West Yorkshire
Globecar Campscout
Hi Trevor,
I have used A and A Caravans (Martin Bushnell) for an exchange EBL220-4 and the returned unit had no problems over 2 years and the turn around time was by return. Martin Bushnell was a treat to deal with and I'd use him again.
53,476
150,187
If your solar is going into the EBL it can stay the same, brain wasn't in gear earlier.
LR1218 is a bit old hat, it's only a single stage charger doesn't even drop to a float charge, OK on Gel's I wouldn't risk it on anything else.
Apr 27, 2016
6,874
7,995
Manchester
A class Hymer
Since the 80s
The EBL has the split charge relay built in. If you just connect the B2B between the batteries, and do nothing else, the split charge relay will short out the B2B and stop it doing anything different than before. There are many possible workarounds to solve this problem.
EuroTrotters
Jul 18, 2009
11,189
17,846
HYMER B644
So I’m thinking !
re-route solar with new controller
Fit B2B
Disconnect fuse and mains to ebl99 as per Lenny HB
Connect mains power to victron to allow mains charging ?
53,476
150,187
So I’m thinking !
Fit B2B
You can still wire a new solar controller via the EBL, if you have an LCD panel the Votronic controllers have the data link so you can bring up the same info as you can now.
Nov 4, 2011
5,943
39,030
Uk
You could change to a Votronic solar regulator and wire it into the battery cables connections on the back of the EBL.
Apr 27, 2016
6,874
7,995
Manchester
A class Hymer
Since the 80s
The Multiplus charger is 80A, which is too much for routing through the Auxilliary Charger socket on the front of the EBL. So best to go direct to the leisure battery. In that case you'll lose the EBL battery % charge level monitoring, but the voltage readings will still be OK.
Once you have done that, routing the solar through the EBL is not necessary, because the charge monitoring won't be accurate anyway. So you may as well go direct to the battery with the solar too.
The B2B is also less of a problem too. You can just disconnect the starter battery connection to the EBL and use it for the B2B input. If you connect the output straight to the leisure battery, and keep the existing EBL connection to the leisure battery, everything should work as before. Apart from the battery % readings, of course.
If you want accurate % charge level monitoring, you could add a BMV7xx or a SmartShunt, but that's not absolutely essential.
The new mains charger will no longer trickle-charge the starter battery, so some arrangement like a BatteryMaster might be required.
6,874
7,995
Manchester
A class Hymer
Since the 80s
I'm not the best one to ask about B2Bs. I have a 48V LiFePO4 battery, and the only 12V to 48V B2B I could find was a Sterling. It works fine, but I didn't look around comparing different brands like you can if you want 12V to 12V.
You should make sure it's a high enough amps output, but not exceeding what the batteries can accept. Also that it can be set to the correct profile for your battery type. And Lithium if that's on the cards in the future.
53,476
150,187
Just looking for one I don’t have to connect to the alternator at the moment
Best to use one that triggers from the D+ on the alternator as if you have solar charging the Starter battery with a basic B2B set up you can end up with the B2B turning on when the battery voltage rises and you end up with it cycling.
You can pick up the D+ connection on the EBL alternatively you can just connect the B2B trigger to a live ignition feed not quite as good as using the D+ but it will only turn on when the ignition is on.
Dec 17, 2016
960
968
Malvern
Hymer B525 2006 A cl
Being as the B2B won't be going through the EBL ( as per autorouter ) you could have a higher amp output Votronic one 70 or 90A I think - depending on you batteries max charge rate. The schematic for them (attached) shows the option of putting in a relay ( that they sell) that will the charge the cab battery.
Apr 27, 2016
6,874
7,995
Manchester
A class Hymer
Since the 80s
I think it's a good idea to make the effort to feed the B2B a D+ (engine running) signal. It's not so hard anyway. The D+ comes in on pin 3 of the 5-way EBL connector, and goes out (to the fridge) on pin 2 of the 4-way connector. You could tap into either of those wires.
Even easier, if you've disconnected the starter battery wire from the EBL (to connect to the B2B input) then the now redundant EBL starter battery connection will act just like a D+ signal. It connects to the Leisure battery when the engine is running, and is disconnected when the engine stops. It might need an inline fuse, maybe 2A.
If the starter battery is only ever charged by the alternator then voltage sensing can work OK, but when you add mains, solar and battery maintainers then unwanted triggering of the B2B can easily happen.
EuroTrotters
Jul 18, 2009
11,189
17,846
HYMER B644
Thanks.
don’t mind picking up D+. It was the idea of having to wire to the alternator like the victron one
Apr 27, 2016
6,874
7,995
Manchester
A class Hymer
Since the 80s
In the Victron diagram, the red wire to from the B2B to the starter battery/alternator is just the wire that you've disconnected from the EBL starter battery input. There's a permanent connection from the starter battery to the alternator which is left undisturbed.
It's a voltage-sensing B2B. However you could wire the remote on/off terminals to a small relay, with the coil triggered by the D+ signal. That way, it's voltage-sensing while the engine is running, but definitely off when the engine stops - so no unwanted triggering due to voltage rises.
Hoovie
1,249
1,689
Autotrail
If you disconnect the starter battery wire into the EBL, will the fridge still work on 12V when it sees the D+ go high? does that mean the Fridge 12V is coming from the Leisure rather than the Starter battery generally when you have an EBL installation?
You suggest feeding a B2B from the Starter Battery connection you remove from the EBL. Nice and handy, but any issues with the increased current from say a 40A B2B? thinking if it were speced up for an EBL at what? 18A? the cable may be too light for 40A?
Not done anything with EBL99s so any handy tips on disabling the internal split-charge but keeping the various potential functions like 12V Fridge etc still working as previously would be good :)
Dec 17, 2016
960
968
Malvern
The EBL 101 which I have is fine with up to 50A according to Udo Lang at Schaudt. I expect that the EBL 99 is the same. With the 50A Votronic b2b you can dial down the current if you are concerned.
Hoovie
1,249
1,689
Autotrail
It is a 30A B2B I am looking at using, but the one I have in mind puts out around 10% extra, so the "40A" I quoted allows for a bit of leeway :)
Thanks for the reply. appreciated.
Apr 27, 2016
6,874
7,995
Manchester
A class Hymer
Since the 80s
On EBLs, the fridge 12V comes from an independent wire from the starter battery with a 20A fuse on it. That means the main starter battery feed only supplies the split charge relay, so nothing else is lost if it is disconnected. Even the starter battery charging from the mains goes via the fridge wire so that's not lost either.
The main starter battery feed normally has a 50A fuse on it. It is specced for the alternator current when the split charge relay is closed, so it's good for 30 or 40A, or up to 50A according to Schaudt.
Hoovie
1,249
1,689
Autotrail
I remembered a while back I was looking at the wiring diagram for the Schaudt WA Booster and that has a nice diagram of how a B2B is added to the EBL ...
