ShiftZZ
Any software to do this?
TIA
TIA
Note: This feature currently requires accessing the site using the built-in Safari browser.
From or to?
Either way drag & drop works.
Write a batch file if it's a regular job.
Forget about writing a batch job thenYou see Graham that is Greek to me.
I sort of understand what a SD card but that’s it.
What does it mean in idiot speak ( which I am fluent in ) ?
Great People, maybe you can help me
I have photos stored on an Eyefi Wifi SD Card
Eyefi is now defunct
Anyone know a way of transferring the photo's
Layman terms please
TIA Ian
Put your SD card in the reader.
Highlight the files to be backed up in Explorer and drag them to the SD card (or from the SD card to the receiving folder if it is the card which is being backed up).
ThanksPlug it into a lap top.
Go to 'my files'
It should be there, double click it.
Then right click on the folder you want and select "copy"
Then open where you want to put it (like where your other pictures are?)
Right click on a space between files and select paste![]()
No the laptop will read it if it has an sd card slotThanks
Do I need a reader?
If so which one ?
TIA
ThankyouSomething like this will do the job if you computer/laptop doesn't have an SD card slot.
https://amzn.to/2TY76d3
ThankyouNo the laptop will read it if it has an sd card slot![]()
That slot with the SD symbol in the computer (if it has one) or an external device as mentioned in other posts aboveWhat’s a reader?
You need to identify whether there are any hidden files and how access is restricted in order to decide if any software could overcome the restriction.I am aware of copy files, but this SD is the sat nav disk for my car, I suspect there are files that copy and paste may not work.
Nope, thats why I was asking if there was some software.You need to identify whether there are any hidden files and how access is restricted in order to decide if any software could overcome the restriction.
Are there any backup instructions in the car handbook and/or on the sat nav provider's web site?
You could ask the garage or e-mail the sat nav provider to ask.Nope, thats why I was asking if there was some software.
An academic rank above senior lecturerPut it in the reader.
What’s a reader?
You can't copy a satnav card completely it has hidden files, you can only back it up via the satnav software.I am aware of copy files, but this SD is the sat nav disk for my car, I suspect there are files that copy and paste may not work.
I have a Clarion stereo (Windows CE) running IGO Prima mapping supplied by TomTom. If you copy the card unit refuses to recognise it.most sat nav sd cards are ok to drag and drop, but the only way to prove it is copy the entire root structure to another card and see if it works. i know it works fine for tomtom as the hidden os is linux based now and used to be windows on earlier models
only ever come across one that uses a hidden system token registered to the licence
