Safefill cylinder making a hiss (2 Viewers)
Jun 10, 2011
464
361
Yorkshire (nr. Leeds)
Since 2011 (so a bit of a newbie)
I filled up my Safefill cylinder last week and when I came to turning the tap on this week it was making a little hiss.
Luckily, we have a calor cylinder as well so I swapped them over as I figured having a hissing gas cylinder was not a good idea.
Anyone have any ideas as to what I can do to fix this?
Dec 6, 2011
11,605
25,464
South Wales
Coach built Adria
If its hissing with the tap off then you need to put that well away from everything and in a well ventilated area. šŸ˜²šŸ˜²
But if it's only when the tap is on then you will have a likely have leak at a union.
Oct 26, 2014
1,873
3,208
Dumfries and Galloway
Pilote P696GJ
I had the same problem when using a gas pigtail made of brass tightened it slightly more and it cured the problem
Oct 26, 2014
1,873
3,208
Pilote P696GJ
Have you any more info on your pigtails, Just bought a couple of safefills this week
Feb 5, 2019
26
38
Kent, UK
Warwick xl
Lots 15 year's caravans, now camperVan
Send it back to the company, I did and they fixed a none filling cylinder
Aug 6, 2018
215
430
GLOBECAR CAMPSCOUT
Since 2019
I've just swapped over our gas cylinders today, as one ran out last night. My first attempt was by feel only as I couldn't see into the cupboard at the time and the connection hissed. Upon closer inspection I saw that the rubber pigtail had got left behind in the old cylinder valve. After prising it out of there and putting it back on the connector, all is fine.
68c
Oct 22, 2019
1,822
2,803
Southampton
2001 Pilote 270
Just to confirm, are you saying the black rubber tip on the brass connected had come loose and was left in the old cylinder?
If so, this needs to widely publicised as if buying used vans one may not know there should be a rubber tip and so lead to a dangerous situation.
Aug 6, 2018
215
430
GLOBECAR CAMPSCOUT
Since 2019
That's exactly what happened.
yorkieman
Jun 10, 2011
464
361
That could be what's happened. I can't see a black rubber tip anywhere. Should the rubber be attached to the gas pipe/lead or to the cylinder itself?
Aug 6, 2018
215
430
GLOBECAR CAMPSCOUT
Since 2019
it should be attached to the lead. Mine had come off within the cylinder connection, looking just like a flat washer until removed from there.
Aug 6, 2018
215
430
GLOBECAR CAMPSCOUT
Since 2019
It would explain why one cylinder leaks and the other doesn't.
Jan 8, 2013
8,491
11,530
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
I bought them from the LPG Shop in Leicester. Plus a Tee piece to connect them together.
Bluethunder
107
142
Peterborough
Elddis Autoqest 155
6years
Bluethunder
107
142
Peterborough
Elddis Autoqest 155
6years
I had the same problem but found out that I had overfilled the tank after a few minutes it stopped, apparently the tank should only hold 80% and I had kept my hand on the button at the pump trying to get too much in it
Dec 6, 2011
11,605
25,464
South Wales
Coach built Adria
you should not be able to do that there should be an auto cut off at 80%
yorkieman
Jun 10, 2011
464
361
I did find a black plastic circular thing in the cabinet David. It is flat on one site and curved on the other. I've attached some photos. Is that it?
yorkieman
Jun 10, 2011
464
361
That could be it as I did fill it right up, although I stopped as soon as the pump clicked off. Maybe I could connect it back up and leave it standing outside for ten minutes and see if it goes away.
yorkieman
Jun 10, 2011
464
361
I bought them from the LPG Shop in Leicester. Plus a Tee piece to connect them together.View attachment 500017
That looks cool. So just to be clear, you have two Safefill cylinders, connected together, both at the same time, so you don't have to worry about swapping them over. If that is the case then you just need to fill them both up each time and you're good to go for weeks. Cool. I didn't know you could do that.
Feb 14, 2021
3,627
7,821
Milton Keynes, UK
Burstner Lyseo 727G
Yes, that looks like the type of rubber that should be on the end of the hose that goes into the gas bottle.
Apr 22, 2018
6,825
12,585
Herts.
Adria Coral lowline
That is the sealing washer off the end of the fitting. Same thing used to happen to mine before swapping to permanently plumbed refillable system. That will be the cause of your hiss
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
I had a Safefill bottle that starting hissing, even with the handwheel off. A component of the valve itself had slightly unscrewed itself and needed nipping up with a special tool.
Aug 6, 2018
215
430
GLOBECAR CAMPSCOUT
Since 2019
Thatā€™s exactly it - pop that back on the hose connector and your hissing should stop.
Aug 6, 2018
215
430
GLOBECAR CAMPSCOUT
Since 2019
The flat end is the hose end, the thin end of cone goes into the cylinder connection.
Jan 8, 2013
8,491
11,530
Burstner Lyseo 690G
We only ever have one open. When its empty we open the other one knowing we have at least three weeks to refill it. We do fill them both at the same time. The tee is a special gas non return valve type.
