rv oven HELP (3 Viewers)
do1977
86
where i park up
A class rv
i have a oven in my rv it is a magic chef no matter what temp i turn the dile to it burns the pizza has any one else had this??
algill
625
213
Derbyshire
Fifth wheel
Don't try to cook your food directly on the shelf above the gas flame. You need a wire rack type shelf which you can put in higher up.
Gill
D
do1977
86
where i park up
A class rv
i no that and there is a shelf that i used
just have to eat out ha ha
muz
133
4
eastwood notts
a class
10 years
oven
hi do1977 when you find out will you let me know as dragon burns every b----y thing in ours they are not the same as uk ones.muz and dragon
IanH
158
5th wheel
The trick here is to put a pizza stone on the metal plate directly above the flame ,the Americans also use a ceramic tile .
You will find nothing burns on the bottom and things cook more evenly
Ian
43,332
49,525
we have a clay pizza plate.
pop it on the plate, put in the oven and it comes out cooked.
dunno where we got it though. :Doh:
is your oven temp control (thermostat)working ok ?
pepe
6
hi had same problem could not get on with it. i changed mine for a spinflo caprice just had to remove the bottom cupboard which is now the pan store at the bottom of the oven. got it off ebay about £300. regards mick
2,343
10,178
Not what you want to hear ... but best advice .. Bin It ,
everyone I know who had one got rid of it and fitted a British make..
I have a SMEV fitted. :thumb:
moandick
1,312
112
Landrake, Cornwall
Euro-shed
We mastered ours in about 11 months but it was hard work so in the end, like scotjim, we binned it and bought a 'Bush' electrical oven with rotisserie and griddle plate mounted on top.
Magic - there is nothing quite like a 'joint' properly cooked on a rotisserie - we have to fight the cats for the 'pork crackling' - or the taste of a properly cooked pizza.
We are looking around for a dish-washer small enough to fit in the space left vacant by the oven - maybe a 'drawer' type dish-washer
9
As well as Smev and the other brands mentioned, you can also fit a Stoves oven, they offer an LPG range which you can pick up for best prices from local Narrowboat chandlers. Their 500 DIT model fits in the space of most US RV ovens and includes oven, seperate grill, 4 burner hob with a glass lid (which can be removed if neccessary).
Bonus being is that with the warranty if anything goes wrong, a nice fella from Stoves will come to you and sort out any problems.
Personally I would bin the magic chef and replace with a popular European model.
PeteH
6,853
9,030
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
Oven?
Mine came with only a Hob, binned that and fitted a "caprice" oven £220-00 curtessy of Mr O`Leary (often seen at some shows). No Problem, have just enjoyed part of 2 Pizza`s cooked in it to-night, (the grandson had most of them!!!.
pete
bashers
108
Bedfordshire
RV
3! Been boating for years. Now just bought an RV
If you're not up to binning the oven yet, the owners manual suggests that burnt food is caused by insufficient pre-heat time.
As the "blow torch" used in this oven warms the interior, the base plate gets much hotter than the desired temp until the selected temp is reached.
give it a good 10 minutes to warm up properly and cook high up on a shelf and it will be fine
After burning far too much food, I've not had a problem since i allowed the preheat time.
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
Quite right, We not only cook but bake in ours, everything is perfect.
Have heard many times the words,"I cant get on with the American oven."
If you leave it on for 15 mins before you cook with it,it will be fine.
Dont forget to convert from F to C though.
