Ring RAC900 12 volt tyre inflator .. broken. (1 Viewer)
2,353
10,223
While on the aire at Gravelines, a motorcyclist came over from the road and asked if I could help with a tyre inflator.. his rear tyre was soft..
I said Yes.. no problem.. I have just the job.. and fetched my almost new Ring RAC900 12v pump from the locker.. Meanwhile he and his pillion passenger pushed the BMW over the grass to our van..
I connected the pump and switched on.. the gauge pressure shot up.. but no air was going into the tyre.. Puzzled, I had a look and found that there was no pin in the inflator connector to open the tyre valve.. so air could never go in..
He also had a look but came to the same conclusion.. the air couldn't go in without opening the valve..
He thanked me, they were from Belgium and had been touring Cornwall and Devon.. now on the way home.. we said goodbye and he said he would ride to the next garage.. about a mile away..
Yesterday I had another look at it and tried inflating the van tyre .. no good it wouldn't work.. so I called Ring Technical help.. 0113 2132000
I explained the problem and the guy said no problem, give me your address and I'll post a new connector.. complete with pipe and gauge..
no quibble.. no questions, no asking for receipt or proof of purchase... just a friendly helpful guy..
well done Ring ..
I have no idea how the part came to be missing or broken.. I've only used the pump a few times.. so if you have a Ring, check it actually inflates tyres..
The part being replaced is the hose in the bottom part in the photo with the gauge
1,201
3,039
Bournemouth and Gibraltar
Since 2003
I'm looking for a reliable air compressor myself after finding out that the supplied one on our Burstner is next to useless....actually it is useless.
This one looks the business but I am concerned that it may be too technical for us in that it needs to be connected directly onto the battery. Is this a relatively easy thing to do? (Can I connect the terminals to my leisure battery without disconnecting the motorhome terminals?)
Alternatively, we have a powerful air-suspension compressor fitted internally. Might this be adapted to also provide emergency tyre inflation too?
Apologies if I digress.
2,353
10,223
@sciac2001 I connect it onto the engine starter battery, it's easier to access, my leisure batteries are under the cab seats.. but you could use the leisure battery without disconnection any cables..
It CAN'T be used with a 12v plug .. or ciggy socket.. at 23 amps, the current draw is too high
Your air suspension compressor could probably be adapted to inflate tyres.. you would need to check with the manufacturer first..
a T connector with an isolating valve with a push fitting connector, and a length of air hose with a tyre inflator would be required.. I had this on my RV which had air brakes and self levelling suspension..
but it may just be cheaper and easier to buy the RingRAC900 ..
GJH
29,450
38,827
None, now sold
2006 to 2022
I bought an RAC600 a few years ago, having seen a review, and it was fine on the few occasions I had to use it until it died last year when Jim's flashy red thing started flashing on one of the tyres.
We were in Doncaster at the time and found This One at Clas Ohlson which worked a treat. It's now been superseded by This One which is a bit heavier duty.
2657
I've had the Ring RAC 900 for quite a few years, possibly eight when we bought the 5'er.
It has worked faultlessly many times but they do have limitations, I never run continuously for long periods, which would be needed for inflating a large tyre from near flat.
For general purpose topping up etc it is a good quality piece of kit but it is still a relatively small compressor and needs trwating with a little respect.
Reactions: GJH
GJH
29,450
38,827
None, now sold
2006 to 2022
A good point which we all need remember about all small compressors (y)
2,353
10,223
totally agree..
and I am fastidious about caring for my tools and equipment..
I've no idea how the adapter came to be broken.. only used it a few times to check the van tyres and put a bit of air in.
I suspect it was faulty... rather than damaged by me..
in saying that.. a tyre inflator should be robust.. and not easily damaged in normal use.. I have a couple of old foot pumps, decades old, that have seen plenty of service and rough handling .. and still work ok..
GJH
29,450
38,827
None, now sold
2006 to 2022
And the reason you now use an electric pump is that you have a couple of old feet, decades old, that have seen plenty of service and rough handling
Sorry, you need to subscribe to see this content. Subs are £20 a year. You Can Subscribe Here
Log in or register now.
11,956
16,571
Your air suspension compressor should do the job. Contact the supplier - they may even supply a kit for the purpose.
2,353
10,223
And true to their word.. replacement arrived today.. great service..
it's clear now what is missing...
old on left ..
2,353
10,223
I bet you just checked though. :LOL:
nah.. I'm not that silly :whistle:
I was holding both in one hand and the camera in the other.. set on macro.. not a great idea for a clear photo..
the broken one is closer to the lens.. hence looks bigger..
Feb 16, 2013
19,742
52,061
uttoxeter
ambulance conversion
50 years
Does the middle bit screw in, if so I'd check its tight, strange for it to break
