It's the RCD that protects yes it is double pole not the MCB.I used to worry about reverse polarity but these days it's not so important. Most vans have double pole mcbcs these days so reverse polarity doesn't matter.
So are ours. It reminds me of the canal boater who gave himself a nasty shock when stripping down an appliance having turned the socket off but not pulled the plug out. In his case it was an inverter not reverse polarity that was the source but the principle is the same, don’t rely on a single pole switches. Also a reminder that many inverters, including my Victron, achieve 230V by sending 115V out of phase down both wires.I don't worry about it either all my sockets are unswitched.
And that includes when they visit the UK ! If you can get your head around what reverse polarity means in an end user sense, you will realise it doesn't even register on 'the things to worry about scale', just don't open up any electrical items - and how many of us actually do that without unplugging it first? I can't even get my MiL to do it ...Never tested for it or worried about it. I don't think I've ever seen any Europeans do so and yet they all seem to use their motorhomes perfectly happily.
A 3000w inverter would charge them up pretty quickly thoughHaving correct polarity is vitally important otherwise your fridge would heat, your oven would cool, you vacuum cleaner would blow and your leisure batteries would discharge. Insert tongue in cheek emoticon here.
Would that make my kettle into a decent ice maker?Having correct polarity is vitally important otherwise your fridge would heat, your oven would cool, you vacuum cleaner would blow and your leisure batteries would discharge. Insert tongue in cheek emoticon here.
and a little know side effect is that you would grow hair between your toes when your motorhome is connected to a reversed polarity. at least thats how it happened to my MiL i was told ....Having correct polarity is vitally important otherwise your fridge would heat, your oven would cool, you vacuum cleaner would blow and your leisure batteries would discharge. Insert tongue in cheek emoticon here.
UK MHs also mostly have double-pole MCBs, and according to the latest regs that's what they should have. Single-pole MCBs are only found in older MHs and some self-builds.It's the RCD that protects yes it is double pole not the MCB.
You will only find double pole MCB's in foreign vans.
True for German/Spanish sockets, but not true for French sockets which have the reversed earth pin sticking out.That European plug will simply reverse in the socket, so that's the easiest way.
To answer the question, one end is a moulded plug that can't be altered, so the only choice is the blue socket.as above which end do I alter to make this reverse polarity. thanks
I seem to recall they had RCD protection before it became common over hereYou'll probably find, unlike ours, European sockets can be wired any way the sparky wanted.
If you need to ask, I think it's far safer not to change anything.
Brown isn't just the colour of SH1T ... but if you do touch a brown wire you could be in it ...Is there someone out there wot knows about this stuff who can confirm this: reverse polarity on AC isn't really an issue for the kit it's operating because its Alternating Current which actually pulses backwards and forwards metaphorically speaking, thus reversing the polarity 50 times a second. Where it does matter is knowing that the red cable will bite, but the blue or black one probably won't. ( I say probably because of the double switched light at the top of the stairs - sneaky bastard is that one). Also: polarity matters in the UK because typically we use single pole isolators with fused appliances, and not so much in France because they use double pole isolators.
