Replacing Rubber ‘O-Rings’ on Kitchen Tap (1 Viewer)
Jan 12, 2009
66
90
Colchester, Essex
Dethleffs Esprit
Hi has anyone replaced the o-rings on a kitchen tap, MH is Dethleffs Esprit, did you just replace them and reassemble or did you use a silicon grease of some sort to ensure they were water tight. Don’t want to put everything back to find out still have an issue. Any thoughts?
17,649
43,471
I grease them to help assembly and ensure a good seal. Are you sure it was the O rings and not weeping down from the cartridge?
DaveNorthwood
14
5
Autotrail Delaware
Check the o-rings are still plyable, not cracked or brittle, especially the hot water feed o-ring. Use Vaseline to lubricate them if have no silicon grease.
Jul 24, 2009
4,336
105,291
South Yorkshire
Since 1999
Are they the original O rings or the replacement ones? If the latter are they genuine spares or ones sourced from a selection of O rings? The reason I ask is because the section looks a bit big to me. Too much interference and nowhere for them to spread to in the groove. I could be talking out of my a**e as usual. ;)
Jul 6, 2016
1,547
1,264
West Sussex
Carthago Chic A clas
Since 1990
The tails are normally held in place by a small plastic peg located between the hot & cold feeds on the base of the tap. The peg fits in the groove on the tails to retain them in place. Best to lubricate the O-rings with either silicone spray or grease.
You may find you have to remove the tap from the work surface to insert the plastic retaining peg. If so, you can test the tap/pipe system insitu for any leaks. As mentioned previously, the leak may be coming from the body of the tap, possibly the cassette.
Tiny
Jan 12, 2009
66
90
Colchester, Essex
Dethleffs Esprit
Many thanks for all the replies, not sure if the o-rings are original, MH has had 2 previous owners, 2006 model. Has any one a contact for getting original Dethleffs parts?
Jan 28, 2008
10,132
18,414
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
i had three of those taps in 2 years ab solute rubbish i replaced the tap with a blanking plate and mounted a domestic tap adjacent to the sink, not an option if you need the microswitch
17,649
43,471
unless you put a push button switch next to the tap
